Fuchs Finish Question
OK stripped my first wheel and this is what I found, any thoughts on how to proceed? Thanks for any help.
Old 05-11-2010, 09:46 PM
a.k.a. G-man
Geronimo '74's Avatar
What did you use to strip it???
Is that paint or some kind of coating?
You'll probably need to remove that, so strip more.
What are your plans with the wheels? Paint, polish??
Old 05-11-2010, 10:19 PM
Left over anodizing. Just remove it to the bare aluminum if you plan on polishing them. If painting, just roughen it up.
Old 05-12-2010, 04:14 AM
peon77's Avatar
I want to strip my wheels too, but I wont if they are like that. What is the date on your wheel? Mine are 10/76. I have heard that the factory wasn't concerned with the anodized finish since the centers were getting painted.
75 911s
86 951 sold to make room for baby seat
09 335i 6MT
NVH
Old 05-12-2010, 05:32 AM
a.k.a. G-man
there's really no reason not to strip them if you want to.
The OP's wheels will come out as new after he removes the anodizing.
Once the anodizing is off, you can do whatever you want.
(tell your wife Pelican sure beats a stripclub...., she won't disagree...)
Old 05-12-2010, 05:39 AM
I've refinished enough to see that the whole wheel is anodized and then the centers are painted. Mine looked like those before I striped, sanded and polished to a mirror finish.
Old 05-12-2010, 06:31 AM
Fastracer73's Avatar
I have blastered Fuchs with glass beads. Turns out smooth and good to work with afterwards.
Some inspiration:
FUCHS 7" & 8" 16" makeover Part One
I'm now working on a 8"/16" -and 9"/16" - that will be "part two"
Fuchs - o - maniac
-78 911 SC
-65 912 (911 R project)
Old 05-12-2010, 06:37 AM
ddubois's Avatar
I recently refinished mine using this process.
1.) Strip anodizing with oven cleaner. As others have mentioned that is anodizing you still need to remove.
2.) Wet sand working up to 1000 grit.
3.) Polish using aluminum wheel polish and the cone shaped foam polisher from Mother's in your drill. This thing is a huge time/finger saver.
4.) Clean and paint as desired.
5.) Apply carnuba wax on the polished surfaces.
Figure around 4 hours per wheel.
Doug
71 911T
Old 05-12-2010, 06:51 AM
kodioneill's Avatar
Send them to Al Reed, to me it's not worth the time or effort , you can't possibly do as good a job for the price. Do a search hundreds of posts on this subject.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 05-12-2010, 07:19 AM
How long does it take the oven cleaner to work? Is it a multi step process?
To give you guys some background I just bought the car about a month ago. All wheels were painted black:
Stripped the spare and it looked like this:
Stripped the first wheel that was on the car and you see what I ended-up with. Since it looks like the anodized is off of most of the wheel I would like to take it the rest of the way and polish.
As a back-up, anyone have a # for Al or any other polisher they recommend?
Old 05-13-2010, 06:19 AM
boxster03's Avatar
I would keep that nice original spare with original 185/70 Dunlop as is.
Member #750 Early911S Registry
1970 911E
I know Where Jerry S. has his NYC Garage
Yadda Yadda Yadda
Old 05-13-2010, 07:41 AM
I agree, was very pleased witht he way the spare turned-out.
Old 05-13-2010, 11:17 AM
+ 1 on that for sure!!!
Regards
Old 05-13-2010, 07:41 PM
Milo2361's Avatar
yes left over anodization. I just refinished mine (new thread coming soon with pics ) and it looked similar(smoother, but same coloring) to yours. I used a combination of bob tiltion's hand method(scotch brite) and someone elses(cant remember it but its in one of the fuchs threads) he used grinding wheels. mine are kind of a crude finish, but you can only see the imperfections if you're less than a foot away. details to come in a new thread.
1998.5 Ram 2500 Cummins
Old 05-13-2010, 08:45 PM
OK, this is with about 4 coats of oven cleaner and an hour plus of wet sanding w/ 1000 grit paper. Thoughts? I think I am almost there. Plan to polish these up.
Old 05-13-2010, 09:36 PM
Finished w/ the stip, sand and polish. Here are the results. Trying to decide if I should trim-out in black. Thoughts?
Old 05-28-2010, 06:33 AM
Great progress....I think trimming in black would finish them off nicely!
I have to do this to the rim for my spare....how much time does it take to oven-cleaner/sand/polish one rim?
Old 05-28-2010, 07:26 AM
It took me between 4 and 5 hours per wheel (probably high b/c of the learning curve). I had to apply the oven cleaner 5 times, the center part of each wheel was pretty bad. I then wet-sanded w/ 220 - 660 - 1000 coat paper.
Old 05-28-2010, 10:44 AM
