UNDER CONSTRUCTION!
carrera turbo's Avatar
How many dash variations are there on the speaker grill over the years?
Hello there "POST PICS OF YOUR ORIGINAL TO YOUR CAR DASH PADS"
I just bought a 74 911 parts car today and was wondering how many dash changes Porsche made on the speaker grill area, I ask this because after looking the car over i had not seen the dash that this car has in it. Im thinking maybe it was a universal replacement as it has no speaker grill just a small area of holes or perforation where the speaker would be. I would describe it as an octagon shape or something close. I didn't have my camera and the car is 80 miles north of here and wont get it till Wednesday. So my question is how many different variations of dash covers did Porsche produce. This appears to be an old dash with no cracks and according to the owner been in there for years. i have searched for pics of dashes and figured i would start a thread on what the differences might be. I will post pics after i get it but just curious as what dashes where available in what years. I have search on here and looked around and couldn't find any good info to speak of.
thanks guys for any help i just loose sleep thinking of the strangest things
cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 02-27-2010, 08:59 PM
1964-1968 : Two piece dashpad, metal armature, 3 defrost vents
1969-1975 : one piece dash pad on metal armature, 2 defrost vents, removable speaker grill with rectangular hole pattern.
Some replacement grills had a diamond hole pattern
Factory produced a full "one Piece" dash in response to the cracking on the removable speaker version. This was commonly available as a replacement part from Porsche. It was not a production fitted piece. Diamond hole pattern for the speaker holes. Two notches for defrost vents
1976: One year only dashpad with no speaker hole opening. A lot of people claim this was also fitted to the RS in 1973, but there is no published material to support it that i have seen. 2 defrost vents
1977-1983: One piece dashpad with no speaker opening. Leading edge center a/c vent. Two defrost notches
1984-1985: One piece dashpad with no speaker opening. Leading edge a/c center vent larger plastic outlet than 77-83
1986-1989: One piece dashpad with no speaker opening, same size a/c vent as 84-85. Long defrost vent at base of windshield with separate metal trim
1989 C4- 1998 : One piece dashpad with no speaker opening, same size a/c vent at 84-89, plastic trim caps on each end to cover revised mounting points. Long windshield base defrost vent with separate metal trim
The above is all from memory, so open to confirmation from others posting here
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 02-27-2010, 11:43 PM
cbush's Avatar
very impressive run-down on dashes! That matches what I know with my 70 and 75--including the replacement dash as described above that I bought for the cracked 70 dash.
Chuck
70 & 75 911S
96 993 C4S
'10 F-150
Old 02-28-2010, 06:21 AM
UNDER CONSTRUCTION!
WOW
Thanks TRE for the run down this site never ceases to amaze me at the knowledge locked up in the members here. Sometimes i feel a bit embarrassed to ask these questions but am always happy when i do because i have learned now that i have a diamond shaped speaker grill replacement dash in the car i bought.
thanks guys
cheers ed
Old 03-01-2010, 12:22 AM
Been here a while
'69 dashes had a uniquely sized speaker hole
Lewis
looking for 1972 911t motor XR584, S/N 6121622
Old 03-01-2010, 03:01 AM
UNDER CONSTRUCTION!
hello all
i bought a 69 912 over the past week and it has the diamond shaped replacement dash that is mentioned above. the question i have is that i parted a euro 1969 911T some years back and have a dash pad with no vent or speaker hole, so is this a 76 dash pad ? i thought all this time it was a 69 dash pad but now im not sure. it is in perfect shape and i was going to put it in the 69 912 as the diamond shaped one is crack really badly. anyways i was about to install this dash but now im wondering if i should try and find the correct dash pad? i do kinda like the clean look of no speaker grill holes.
thanks for the help.
cheers ed
Old 04-20-2010, 01:08 AM
Jack
I tried looking around (searching), and didn't see any posts.
How big of a PITA is it to put a 88 dash in a 85? From what TRE says, the defrost vents are different, but if I have access to the later AC vents, is it a major pain?
Jack
85 Carrera Cab
Old 05-28-2010, 10:35 AM
