j911brick's Avatar
SC CIS 02 Test port
I did a search and couldn't find information on where the SC 02 sensor test port is. Found the spec for testing, but no help if I can't find the test port. Factory manuals are no help. I have an '80 sc and the 02 system appears to not be working. Also: how do you test temp sensor? Also: not getting a clicking from relay.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 08-14-2011, 10:52 AM
Capitalist and Patriot
911Freak's Avatar
I believe it is located on the left side of engine compartment, it is a round socket mounted in the metal panel next to the rear fuse/relay panel. If I had an engine compartment pic I would outline it for you
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 08-14-2011, 11:10 AM
j911brick's Avatar
OK, I found a plug with cap, and three (badly corroded) terminals. Is that it? WHich terminals do I test with?
james
Old 08-14-2011, 11:25 AM
El Duderino
tirwin's Avatar
Can you describe what got you started on this to begin with? Maybe more details on your symptoms?
Reason I ask is that it is not unusual for people to disable the O2 sensor anyway. It just causes it to run in open-loop mode. Do you need to pass emissions? Otherwise, why bother? Not questioning... just curious. Mine is disconnected on my '83 SC.
Old 08-14-2011, 11:39 AM
j911brick's Avatar
Customer brought the car in with high/hunting idle. Both those are fixed, AFR and timing set per spec, but car does not accelerate like it should.
Found info on dwell test. Duty cycle is 0.3%.
james
Old 08-14-2011, 12:02 PM
j911brick's Avatar
Went back and tested the relay. The relay is bad.
james
Old 08-14-2011, 12:32 PM
j911brick's Avatar
Since the 02 sensor wasn't working the car still ran like crap to spite the fact everything was tuned to perfection. So just for fun I decided to put in an early SC distributor. Now it runs like a scalded ape!
james
Old 08-14-2011, 02:56 PM
911Freak's Avatar
early SC? the one with only 1 vacuum line on the dizzy pot?
Old 08-14-2011, 02:57 PM
j911brick's Avatar
yep. Use the blue hose, plug the red hose.
james
Old 08-14-2011, 03:08 PM
CIS troubleshooting..........
j911brick,
Do you operate an auto repair shop?
Tony
Old 08-14-2011, 05:47 PM
j911brick's Avatar
Originally Posted by boyt911sc View Post
j911brick,
Tony
Yes, part time.
james
Old 08-14-2011, 07:57 PM
