spsfiend's Avatar
What does the 15,000 mile service entail?
Can someone tell me what should be done in the 15K miles service?
Thanks so much!
Gerry
____________________________________
1987 Porsche 911 - OEM 930 Steel Wide Body
2008 BMW X5
2010 Toyota Tundra 5.7L CrewMax
Old 03-05-2010, 12:22 PM
oil change, filter change, air filter cleaned or changed, valve adjusted, belt checked, inspect of change your spark plugs,, drive and smile
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-05-2010, 01:35 PM
E Sully's Avatar
That's a number I passed about 110,000. miles ago.
This is from the '87 manual.
Ed
1973.5 T
Old 03-05-2010, 01:43 PM
Peter Zimmermann's Avatar
At Red Line a 15K service on an '87 Carrera was:
Oil & filter change
Trans oil change w/synthetic oil
Valve adjustment using new hardware and gaskets on the rocker covers
Replace spark plugs
Replace air filter
Replace fuel filter
Date check brake hoses
Inflate tires to factory pressures and inspect tread
Test/inspect front ball joints and tie rod ends
Inspect shocks for leakage
Inspect CV joint boots
Inspect brake pads & advise
Inspect alternator & A/C belts and advise
Check battery & terminals
Check/fill/adjust w/washers
Replace w/wipers if needed
Check every light in the car, replace bulbs as necessary
Evaluate trunk & engine lid supports and advise
Check brake fluid level and advise
Check throttle linkage
Complete visual safety inspection (fuel lines, electrical connectors, seat belts, etc.)
Start car and run until at correct oil temp in order to set idle speed and CO% using digital equipment
Check charging system during warm-up
Test drive approximately 3.5 miles, both city and freeway, and top up oil to correct level.
Keep the Shiny Side UP!
Pete Z.
Old 03-05-2010, 01:47 PM
dshepp806's Avatar
Oil & filter change
Replace spark plugs
Replace air filter
Replace fuel filter
+1,..that's what I'd want see on mine....good coverage.
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-05-2010, 04:31 PM
Senior Advisor
James Brown's Avatar
Isn't that info in the owners/maint. manual?
08 Cayenne Turbo
Old 03-05-2010, 05:08 PM
p911dad's Avatar
Paul, I have always done my own maintenance on our 911, but I am getting old and lazy, especially the valve adjustment. Would you mind sharing what a 15K service costs? Thanks Glenn
Old 03-05-2010, 05:57 PM
80-911SC's Avatar
that is why a search for oil or which oil brings 10,ooo responces
it seems to some easier to ask than walk the 40 ft to the garage, open door and glove box remove book and read. thats like 5 or 6 phases to an answer
have a good one James,
steve
Old 03-05-2010, 06:14 PM
Nine17's Avatar
I've been paying around $450, give or take incidentals like belts, hoses, and wiper blades. Valve adjustment is very important on these cars. Not a performance issue per se, but for longevity.
Old 03-05-2010, 06:19 PM
