Senior Member
Engine mounts, how many in total?
Because I am dropping the engine on Saturday I would like to know (so no surprises) that how many mounting bolts there are in total that need to be removed?
2 in engine compartment 2 at the transmission If other, where?
Projects: 911 -72T EFI "964-look" "Smoky" 914 -71 1.7 D-JET "Rusty" |
There are just those 4. One thing I learned on my first drop, remove the crossmember at the trany first it makes it a lot easier to get to the cables and undo them.
Tom 71T http://www.cheaterswayside.com/911/gallery.asp?sort=0&userid=173 |
While we are on the subject... Has anyone upgraded to "club sport" motor mounts?
Firmer than stock, but not the bone-shakers that the solid ones are. thanks, BB |
Schleprock
Club sport mounts are the same part # as cabrio (and maybe targa as well) mounts. Can't really say if they made any noticeable difference as I replaced them over the winter during a motor drop. Didn't drive the car back-to-back to see the change. Plus, you can't install the sport mounts on the G50 trans. crossmember as they are not removeable like the 915 and earlier cars, so I don't have a good idea of whether or not they make a big difference. Solid mounts definitely will make you take notice.
Kevin L '86 Carrera "Larry" |
I just replaced my 72 with the sport mounts. I have had the car for 11 yrs. Didn't look like the mounts were changed although the tranny mounts LOOKED newer. Before, when ever i would shift from 1st to 2nd i could feel the eng and tranny moving, not any more.
72 911 Although it is done at the moment, it will never be finished. |
