sdrake's Avatar
rust on rotors
Anyone have any good ideas on cleaning rust stains off the hub portion of the rotors? I thought about masking and painting, but I wondered if there was anything I can use to just clean them up that will not hurt the rotor surface??
I just hate seeing that rusty stain through the wheels...
thanks
96 993 Cabriolet - Speed Yellow - Stock
88 944 Turbo - Nautic Metallic
65 Pontiac GTO Post Coupe
Old 04-27-2010, 05:57 PM
crustychief's Avatar
Just wire brush the rust off, hose it down with brake parts cleaner, mask then paint. You won't hurt the rotor surface.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 04-27-2010, 06:45 PM
Here's a real easy solution and only takes 1 minute. This is what I did and haven't seen rust for 4 years. I used a rust converter.
1. Get a metal brush and brush the rust off. Not important you get ALL it off.
2. Brush on a rust converter.
3. Wipe off excess.
It convert the rusts into a black coating which so far lasted 4 years.
Old 04-27-2010, 07:42 PM
is this like the prep you put on bare sheet-metal before priming?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-27-2010, 11:00 PM
thanks
Don't think so. This stuff is meant to go over rust and convert it to a hard surface that can be primed and painted. I'll try to look for the bottle tomorrow. But I think it is just phosphoric acid.
Old 04-28-2010, 01:04 AM
No. Spray can, in the paint section at your auto parts store.
Old 04-28-2010, 09:41 AM
1980 911 SC
Harbor freight
Life's a Beach
Old 04-28-2010, 09:51 AM
84 Carerra, wide body
Loctite makes a version of it. It's available at Home depot or auto stores. sometimes a spray, or in a liquid. It's a latex solution with some kind of chemical that turns the iron oxide rust into a black something else. I've used it on floor pans, metal roofs, and many things for a few years. The great thing about is there is little prep, just get off most of the rust. It doesn't usually stand up to alot of water, I would guess because the latex isn't fully waterproof. It can also be coated with another paint once it dries.
Old 04-28-2010, 10:30 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I paint mine with a cold galvanizing high temp gray paint. Made by LPS available at local Ace Hardware. Worked great on brake rotor hats and exhaust systems.
Kevin L
'86 Carrera "Larry"
Old 04-28-2010, 10:33 AM
Can't find the bottle, but I'm sure it was a rust converter in a white milky liquid. I just brush it on.
Here's a pic of the rotor after close to 4 years, and NOT doing anything. Guess I could use a second application huh? Good part is that the rotor hub doesn't look painted.
Old 04-28-2010, 07:03 PM
ok..... i know what kind of converter you're talking about now
I used that stuff about 20 years ago to coat the roof of a 1971 Camaro that looked like swiss cheese
epoxy primer and Imron coated it worked out great
never a bubble or any trace the roof was screwed up
i'll get some more for my rotors
thx all
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-28-2010, 10:38 PM
