6 cylinder symphony
Getting to know my car - and finding things that need fixing
Well - I've owned my car for almost a week, and I think I've found almost all of the issues that need sorting. Now I need some help.
Just a refresher - the car is a 1984 911 Targa with the 3.2. It has approximately 132000 miles on it. I am the second owner. The car has the 915 gearbox, that was rebuilt about 10,000 miles ago. Tensioners were also re-sealed about then. I'm working through normal tune up issues (belts, filters, fluids). Here are the new problems: Drove around town, and noticed a funny noise. While sitting at a light idling, there is a strange rattle coming from the engine. It stops when I depress the clutch. I'm guessing this is some type of clutch adjustment issue? On the interstate, there is a lot of wind noise coming from the hood cowl vent. Sounds like a jet engine is going to blow the dashboard out! Any thoughts? I have an oil leak (shocking, I know) - looks like it is coming from #6, where it drips down and makes smoke. Have to look at this closer, but I'm hoping it's just a valve cover leak. Finally - the cruise control has "Toyota disease". When I try and set it, the car just accelerates. I've done a search - the bracket at the throttle body is not broken, and I think my vac system is fine. Any thoughts? Thanks in advance! Ken
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife |
Or.....it could just be the noise from the Targa top. I have had my top rebuilt, and it is still loud. I mean, my car is quieter with the top off! At about a hundred, mine sounds like there is a fighter jet idling in the passenger seat. Oh, by the way, take off the top, and go out and enjoy the car.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
6 cylinder symphony
Thanks for the reply -
Nope - I'm sure the front was latched and locked. I also have good seals around the hood, so I don't think that was it. I don't think it was the top either. My top seems to be OK. I'm pretty sure the noise was coming from the cowl vent. Ken
take some blue painters tape and tape up the front seal of your targa on the outside. get a good layer or two so it can stand up to some highway speeds. it won't be pretty but it will be temporary and it will tell you if the top is the culprit.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
If you remove the screen from the cowl vent, you should see the intake for the fresh air blower unit. It should have a foam seal surrounding it. If that is missing, that could be your problem. You can also look at the ducting from the blower to the air distributors by removing the flex tubes (accessible after removing the cardboard cover in the trunk) and see if the rubber seals in the outlets from the air blower are intact.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
muck-raker
Engine rattle: if the noise stops after the clutch pedal is depressed, it could be a throwout bearing.
Oil leak: Sounds like the usual culprits on top of the motor (old leaking breather hose, T-stat gasket and o-ring, etc.) Could also be a leaking valve cover on the intake, but that doesn't happen very often...but the first thing to be checked.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
just a guess but the rattle is probably from the transmission and likely is normal.
915s are notorious for this gear rattle and were fitted w/ rubber center clutches which have their own issues. Most owners replace the rubber center clutch w/ a spring center version to avoid the weight and other issues associated w/ the rubber centered versions. The down side is that the gears rattle on the main shaft. I'd rather have that than a rubber center clutch do a search on exploding rubber center clutches for more info.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
as per kidrock, have a look at the top of your motor for oil residue. If the residue is obvious, I can walk you throught the replacement of: 1. The breather tube and gasket. 2. The oil temp gasket. 3. The oil cooler thermostat gasket. These are the "usual" suspects. Also, while you are back there, you may want to replace the sound absorbing pad that is appended to the back of the firewall. I performed these "surgeries" last year. 4-6 hours. Good luck, Gerry You may pm me again.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 03-21-2010 at 04:12 PM.. |
if its taken a week to find all the problems your doing good,
i have had mine for two and still finding the occasional WTF did they think when they did this that with the "while" I am in there and all Targas are loud |
Just a quick note. The engine oil cooler could also be the culprit. A PIA to fix but to make sure it truly is coming from the top of the engine, a flashlight and a mirror should tell you if it is leaking from one to the leak prone areas. Good luck. It took me 18 months to finally figure out what I had to repair.
Steve 1970 911T SOLD 1989 3.2 Carrera 2013 991 Carrera S |
Nothing to add to the above but the usual necessities are a Bentleys and Wayne's 101 book if you haven't purchased yet. Also welcome to Porsches. Bring it down to the Coffee and Cars sometime, open the hood and you will get more free advice.
![]() Houston Coffee and Cars (Cars and Coffee) | New Website Launching Soon! Ken
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
cruise control
I had the same problem with my 81SC. When I set it to cruise, it would just accelerate. The biggest problem was it also worked with the car in neutral. If I bumped the stalk at idle, it would send the RPM's shooting to redline! I eventually removed the ECU that controls it and did some troubleshooting. It is located near the fan/ducting in your luggage compartment (silver box). If you have searched, you may have come across an electrical troubleshooting guide. That would be my next step. My ECU turned out to be bad. I just left it unplugged and forgot about it. Good luck.
TODD (the past): 1981 911SC (Rosewood Metallic) 1992 Saab 9000 Turbo 1991 RX-7 1987 VW GTI 16V 1984 Mercedes 300SD |
