Hi
Identify This Switch or Sensor please
Hello everyone,
![]() can you tell me the name of this switch or sensor? thanks.
That's the oil pressure switch - PN for my 87 was 911-606-230-00-M85
On Edit - it is NOT the Oil pres switch.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue Last edited by steely; 03-19-2010 at 02:04 PM.. |
If it is for your 84 3.2, it would be a temp switch # 930 606 117.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Hi
opps, ya, for my 84 3.2
thanks. |
Somatic Negative Optimist
Along with that temp. sender, you may also want a new gasket for the breather cap, a new O-ring for the thermostate next to it and a new oil pressure switch which is the ground for the oil warning light in the dash.
The last 3 items are usually replaced when the engine is out.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Oh man - My bad - The Oil Switch is clearly visible a few inches over and down (forward).
Sorry to for the bad info.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
I would advise changing the fuel lines and intake gaskets with the engine out. I see you have a 3.2.
The oil pressure switch and thermostat o-ring probably should be changed, but if they've been changed recently already, they're not that difficult to change with the engine in. On a 911SC, it's an entirely different matter, and should be changed each time the engine is out. |
Get the good, green Viton O-ring for the Thermostat....do not overtorque those thermostat bolts..clean that nasty area REALLY well before removal,..no debris falling inside is a good thing!!!!!!!!!!
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
+1 on the fuel lines and gaskets, etc. and chuck in a crankcase breather gasket if you do the tstat & oil press sw.
