Hi
Targa Me's Avatar
Identify This Switch or Sensor please
Hello everyone,
can you tell me the name of this switch or sensor?
thanks.
Old 03-19-2010, 08:07 AM
steely's Avatar
That's the oil pressure switch - PN for my 87 was 911-606-230-00-M85
On Edit - it is NOT the Oil pres switch.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 03-19-2010, 08:40 AM
al lkosmal's Avatar
If it is for your 84 3.2, it would be a temp switch # 930 606 117.
RGruppe #669
http://www.x-faktory.com/
Old 03-19-2010, 08:43 AM
Hi
Targa Me's Avatar
opps, ya, for my 84 3.2
thanks.
Old 03-19-2010, 08:48 AM
Somatic Negative Optimist
Gunter's Avatar
Along with that temp. sender, you may also want a new gasket for the breather cap, a new O-ring for the thermostate next to it and a new oil pressure switch which is the ground for the oil warning light in the dash.
The last 3 items are usually replaced when the engine is out.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-19-2010, 11:31 AM
steely's Avatar
Oh man - My bad - The Oil Switch is clearly visible a few inches over and down (forward).
Sorry to for the bad info.
Dan
Venetian Blue
Old 03-19-2010, 02:03 PM
I would advise changing the fuel lines and intake gaskets with the engine out. I see you have a 3.2.
The oil pressure switch and thermostat o-ring probably should be changed, but if they've been changed recently already, they're not that difficult to change with the engine in. On a 911SC, it's an entirely different matter, and should be changed each time the engine is out.
Old 03-19-2010, 02:20 PM
dshepp806's Avatar
Get the good, green Viton O-ring for the Thermostat....do not overtorque those thermostat bolts..clean that nasty area REALLY well before removal,..no debris falling inside is a good thing!!!!!!!!!!
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-19-2010, 03:16 PM
steely's Avatar
+1 on the fuel lines and gaskets, etc. and chuck in a crankcase breather gasket if you do the tstat & oil press sw.
Dan
Venetian Blue
Old 03-19-2010, 05:20 PM
