Location: In a dumpster behind Albertson's in Los Angeles County
83 sc help!!!!!
Before you say anything, yeah, I'm a 944 (well actually 951) guy. I now have a 1983 SC, and a problem.
It idles at 1900rpm ![]() ![]() Help me please?????!!!!!
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ![]() 1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
Check for vacuum leaks.
Need more details. Does it always idle high? If not, describe the situation.
I'd think vacuum leaks would make it idle lower (ie. taking off oil cap.) Could be decel valve too. Easy to test and fix if it is. |
It lopes when it is first started, then settles into a nice idle....once it heats up, the idle heads for the moon.
i take it by lopes you mean a low idle and barley turning over.
you may have more than one problem. i would look intot he following. aux air regulator (AAR). check for 12v at the connector or stuck open. WUR- check warm and cold control pressures, (WCP/CCP). decel valve.
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
sounds like your warm up regulator is backwards!
By "lopes" I'm guessing that the idle speeds up, slows down, speeds up, slows, etc.
Yes? |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Give us more info. When did this start? Any recent service on the car? Did you try removing the oil filler cap as per mca. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Tired Member
Sorry but it has to be said...... have you tried the "search" function? Tons of posts here on this and related subjects.
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
