Fast engine idle
FAST IDLE PROBLEM
My 1978 SC has developed a fast engine idle problem. It has always idled at 900rpm but now has an erratic idle. The scenario is as follows: 1. On cold start up, it will idle around 1300-1400rpm for a few minutes, slowly reducing to 900rpm as it warms up. 2. After a few more minutes driving in the 2000 -3000rpm range (and thus a warmer engine), the idle speed only reduces to 1900rpm when the transmission is disengaged from the engine via the clutch. It will then remain at 1900rpm continuously with no reduction at all. 3. If the car is slowed by braking, thus reducing the engine speed below 1900rpm, disconnection of the transmission via the clutch results in a slow decrease (say 3-6 seconds) in engine speed to 1150rpm which is where it remains with no further reduction. 4. A later restart will repeat the above cycle Another problem I’ve noted (and perhaps related) is that a cold start requires repeated attempts (say 4-6) and fast acceleration in the 3000-4000rpm range is very “lumpy”. Any suggestions? Last edited by kevin v; 03-26-2010 at 04:17 PM.. Reason: typo |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Vaccum leak? Our '86 had nearly the same issue when I transposed the throttle assy vaccum lines during some top end work. Try removing the engine oil filler cap. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Virginia Rocks!
#1 describes normal operation.
#2 - 4 sounds like you may have a dying battery/alternator. When my alternator died, the car had a high idle as you describe until the battery died and then it had no idle.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Free minder
WUR going bad?
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Sounds like a classic air leak/lean condition. If so, there are many threads to help you track it down. Try Gerry's suggestion and remove the oil filler cap when the car is warm and see if you get a decrease in rpm. If not, you have an air leak.
Check the pop off valve in the air box (if you have one). Could be unseated or loose. Next, you might try to adjust the fast idle by turning the idle screw, remembering its initial position. If turning the screw clockwise does not reduce fast idle, you have an air leak. You may also have a faulty decel valve. Try removing the hose from the top of the valve and plugging the hose and capping the valve opening. "Blip" the accelerator and see if the rpm rapidly drops to normal idle. If so, it's your valve which may be adjustable on your car. If not, the leak is somewhere else. It's always good to check your fuel pressures as the cold start symptom you mention could be related to too high cold pressure. However, the consistent high idle at warm points more toward an air leak.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
CIS troubleshooting..........
Kevin, Before you do any further diagnostic CIS troubleshooting, check your control and system pressures. This is the first step in any fuel injection troubleshooting. Start from the basic test. Without knowing the control and system fuel pressures, you'll be just doing guess-work investigation which could be very expensive and time consuming. The next step is a vacuum test of the system. Keep us posted. Tony |
Tony,
I'm in Philadelphia, also, and have a few questions relative to my '81 SC's fast idle. Can I get in touch with you by phone? Please e-mail me at kessler993@msn.com . Thank you.
"Life is good" |
