pszemia's Avatar
Need tech info for custom made CDI for my MFI
Hi everybody, 2 weeks ago my universal (and hated) CDI finally died and has been looking for a replacement for it since then.
Here my mechanic recommend me to convert the dizzy to a pointless system, as well installing a new CDI.
My question is if anybody has information about the original bosch CDI, so i can match the techincal data on the new CDI so it will be as similiar as possible to the original one, and what about the pointless system installation??
Also, buying a new coil, any recommendation on it? i mean, solid, in oil, covered with epoxy.
Note: The CDI i am buying is programmable, so i can program the parameteres like RPM limit before buying it. Also i am not buying MSD or permatune, remember i live across the continent and here we have a lot of good national stuff.
Thanksss
Ariel
911 T 2.4 (MFI) 1973 with 911 E fuel pump from 1971
The beatiful Buenos Aires, Argentina!
Old 03-06-2010, 03:37 PM
Max Sluiter
Flieger's Avatar
Here's a good thread: History of Bosch CDI ... toubleshooting info, parts list changes, and schematics ...
Old 03-06-2010, 03:48 PM
pszemia's Avatar
thanks flieger, that's a lot of information, but it's most technical for building or repairing than to make a comptaible unit i think, hahaha
thanks anyway, maybe my mechanic will use it.
Old 03-07-2010, 05:49 AM
pszemia's Avatar
any other with specific data to make a compatible unit?
Old 03-09-2010, 02:11 PM
I am using Pertronix point conversion kit and it is great. Not sure if you can get it there. Works well with stock Bosch unit. I believe the output is 12vdc with a square wave pattern. That is pretty industry standard.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 03-09-2010, 03:29 PM
T77911S's Avatar
i am not sure what you are asking for.
the bosch unit did not do anything special, no different spark duration at different RPM's, it did not change the timing, it just produced a 450v pulse to a coil that stepped it up, about 100 times, ouch, that really hurts BTW. so unless your new one can be programed to change the timing, or, you have a race motor, you can not do any better than a bosch or MSD. i went to MSD because of cost. to me, it is just as reliable and i cant tell the difference, except that my car now runs, plus, if the MSD ever breaks, i can walk into any speed shop and buy another one.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-10-2010, 04:07 AM
pszemia's Avatar
What i am looking for is the output parametres of the bosch CDS so i can clone it.
It's not for racing, it's just to replace my actual CD box (burned and very bad) with a new one, the most similar possible to the original bosch so i can have all the parametres of the ignirion right according to porsche, and can follow step by step the CMA.
Old 03-20-2010, 06:40 AM
Have yoiu looked at the Daytona Sensors CD-1? Maybe that is the one you are considering.
Daytona Sensors LLC - CD-1 Capacitive Discharge Ignition System for Racing
Pretty interesting unit. Have not used one. This is a new product.
03 Boxster
Old 03-20-2010, 02:20 PM
pszemia's Avatar
you mean, that any CD that can output a 450v pulse will work right with the system?
Old 03-25-2010, 07:18 PM
RETIRED
Joe Bob's Avatar
Just get a rebuilt one. Try Ingo at 3.6@cox.net
2012 ML350 3.0 Turbo Diesel
Old 03-25-2010, 07:43 PM
T77911S's Avatar
you are trying to re invent the wheel.
why go to the trouble to build something that does what is already out there. if you are going to build something, build soemthing that puts out more voltage, or can make a longer spark
RACE CAR:: sold
Old 03-26-2010, 07:27 PM
pszemia's Avatar
what i am trying is to get all the possible info from the original CDI, and buy locally a similiar one,because the original one was taken out from the car..
Old 03-27-2010, 08:22 AM
