Mo money = mo parts
Distributor Install Alignment
I am nearing the end of my rebuild and finally installed the distributor today. I have a question about the alignment or orientation of the distributor.
The engine is at #1 TDC. The pulley is directly over Z1 and the valve covers are off, so it easy to confirm I am definitely #1 TDC, not #4. When I install the distributor with the rotor over #1 TDC mark, the closest I can get is a few degrees before the TDC mark. See the picture. Thanks.
Wayne's book says the rotor needs to be "directly" over the TDC mark, but Bentley says "Note: The marks line up approximately, not precisely." Wayne is working on an SC in his book, but he doesn't call out anything different for a Motronic in the text.
Does the Motronic system adjust for this? I searched the forum and could only find a few loose references where it stated that a Motronic doesn't need to be exact. Can anyone give me a definitive answer? Thanks.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 03-27-2010, 11:40 AM
You are good to go,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-27-2010, 11:54 AM
Mo money = mo parts
Awesome...on to the rockers.
Greg
Old 03-27-2010, 03:00 PM
You sould be good assuming you have some adjustment with the distributor.
Old 03-27-2010, 03:54 PM
There is no adjustments in the distributor, what you see is what you have. The next possibility is 30 degrees away..
Bruce
Old 03-27-2010, 04:14 PM
Bruce
Loosen the distributor hold-down clamp, then you can rotate the dist. housing relative to the rotor position. With a timing light connected, you're good to go (or adjust).
Sherwood
Old 03-28-2010, 09:45 PM
3.4 Bigger is better
88-diamondblue's Avatar
No adjustment of the distributor on a Motronic car. One hole and only one position. The computer makes all the timing adjustments for you.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 03-28-2010, 10:34 PM
Almost Banned Once
sc_rufctr's Avatar
3.2 Dizzy... No adjustment slot.
- Peter
Old 03-28-2010, 11:01 PM
"No adjustment of the distributor on a Motronic car. One hole and only one position. The computer makes all the timing adjustments for you."
"3.2 Dizzy... No adjustment slot."
Uh... Errr......Ummmm.....Okay. Thanks for the correction.
Sherwood
Old 03-29-2010, 09:26 PM
Almost Banned Once
sc_rufctr's Avatar
Sherwood
PM sent...
- Peter
Old 03-29-2010, 09:33 PM
