964 C2 Targa A/C dead, Help!
I was driving along in my 1990 C2; A/C roaring nice and cold ( well, as cold as you can get for one of these ) when I had to make a radical evasive turn to avoid this woman t-boning me. She missed but the air went dead. I don't know why that hard move would have caused this but it seems to have. So far I've checked the fuse, there is plenty of freon, the climate unit has been varified as being fine. There are no lights that come on with the climate unit. Any ideas? It's not even summer yet and the heat is here already, so humid.
Old 06-02-2013, 08:55 PM
kuehl's Avatar
Step 1:
When you turn on the AC does the compressor clutch hub engage with its pulley?
Old 06-02-2013, 09:33 PM
wwest's Avatar
WOT microswitch bent into open position?
Stopped blowing or stopped blowing COLD..?
Old 06-03-2013, 07:35 AM
kuehl's Avatar
Step 1:
Step 2:
When you turn on the AC does the blower motor push air through the vents?
Old 06-03-2013, 09:11 AM
did you hear any water sloshing around ? Floor wet?
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-03-2013, 09:52 AM
I mean the A/C is deader than a door nail. There is no power at the CCU when you push the off and on button, the snow flake, nothing. The fuse is fine and the CCU unit has been verified as being 100% not to blame.
Old 06-03-2013, 09:15 PM
No water, no wet floor.
Old 06-03-2013, 09:19 PM
kuehl's Avatar
Time to read the Fault Codes
Shop Manual section D 80/87
Old 06-04-2013, 04:04 AM
wwest's Avatar
Fault Code readers, even the latest OBDII type, do not typically "read" any fault codes other than the ones of EPA interest or designation. Ancillary or auxillary functions such as A/C, ABS, etc, often incorporate a method for reading fault codes embedded within the ECU firmware.
Hold 2 buttons down as your switch the ignition on, and watch the blink sequence of a light/icon, for instance.
Old 06-04-2013, 07:59 AM
