#147 of 2096
weatershield filters for 1972 mfi
Hi!
Has anyone installed water shield k&n filters on a 72/73 MFI? Any suggestions? Thanks. |
I dont' think they will fit, but someone on this board went the itg way and made it work.
72 911 Although it is done at the moment, it will never be finished. |
Max Sluiter
The earlier Magnesium stacks can be modified to work with the watershields or oval filters. The plastic stacks cannot. ITGs can work on either as they are just foam.
I ran these for a while since I only drive about 20 miles every Saturday and the weather is so nice near the coast in Sothern California. ![]()
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
I think the factory filter is the most efficient, unless you go the wire mesh route but valve longevity will be affected.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
There have been plenty of dyno tests and the stock airbox is by far the best for power, performance, and longevity. However.....if you want the look and sound of watershields they can be modified to work. 72 plastic stacks with watershields will not clear a stock decklid. I think they will clear a ducktail though. Im not positive tho.
Darren 1973 911 T MFI 2005 997 Carrera 2001 Toyota 4Runner |
