Msd install to 911 1986 need help
Hi all
I was search forum but i couldn't get answers,
Please tell me How to install my 911 '86 ?
I bought MSD 6AL-2 ,BLASTER COIL 2, DISTRIBUTER CAP, ROTOR, PLUG AND PLUG WIRE,
My 911 is everything original,
motronic 3.2
Thank you
Old 04-04-2010, 08:50 AM
An MSD 6AL is not compatible with Motronic AFAIK.
Lindy
Old 04-04-2010, 09:18 AM
Lindy
MSD can not install my porsche ?
Thank you
Old 04-04-2010, 06:51 PM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
Pelican shows the MSD 6420 as working on all models of 911. I do not know if it will work on your vehicle or not. Double check with your vendor.
Why are you moving to an MSD? What are the symptoms/issues you are attempting to address?
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 04-05-2010, 06:31 PM
I am thinking may be get more torque ,
It is Mistake ??
Old 04-05-2010, 09:30 PM
JOT MON ABBR OTH
I do not know. Most people seem to go this route to replace a permatune (I do not suggest using this product) as the Bosch unit is a bit pricier. It seems to be done more often than not to address an ignition issue.
I would suggest posting on the engine re-build side and get some opinions there. Hopefully someone more knowledgeable will chime in.
I think diminishing weight will get you more bang for your buck initially. There are many older threads on weight reduction techniques.
Old 04-06-2010, 04:20 AM
6 cylinder symphony
MSD = Multiple Spark Discharge.
MSD basically causes your spark to discharge more, thereby getting "better" combustion. Or more efficient combustion. Or so they say.
Actually - with your Motronic, that's what it does too - monitors engine efficiency and adjusts fuel and timing to compensate.
I don't think it gives more torque.
MSD is great for old cars as an upgrade. MSD is good in the right application for newer cars. I've installed a MSD coil pack on my wife's R50 cooper, and I see a difference in fuel economy.
From what I've read, MSD is fine in a 3.2 911 if your Bosch motronic brain has kicked the bucket. Otherwise, you'd be better off looking at other ways to improve engine performance - like getting your engine to breathe better by making adjustments on intake or exhaust side of the engine.
But - I'm not an expert.
Good luck.
Ken
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 04-06-2010, 09:22 AM
Thank you all
Old 04-06-2010, 08:42 PM
