Brake pad pin kit. Replace or not?
I have finished rebuilding my front calipers and also put new pads and disks on the rear. I used the old brake pad pins and retainers. Should I have used new ones. It's a pretty straightforward job but I'm just wondering if it's overkill. tx;
Champaign and Burgundy 3.2 (1986)
Ex-C4 91
Ex C4 93
A8 3.0 TDI
X5
Old 04-11-2010, 09:34 AM
Senior Advisor
James Brown's Avatar
(don't tell anyone but I reused the old ones. there pretty pricey for a pin).
08 Cayenne Turbo
Old 04-11-2010, 09:47 AM
I'm looking at North of 100 euro for front and rear.
Ex-C4 91
Ex C4 93
A8 3.0 TDI
X5
Old 04-11-2010, 09:52 AM
Clean them up with a wire brush and re-using them is just fine. Save $100 for an oil change.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-11-2010, 10:17 AM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
clean them up and reuse them. been using same ones for years.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 04-11-2010, 01:12 PM
I replaced or rebuilt the brakes on my 1989 Carrera 3.2. Like you just did, Garp, I saved at least $2000 dollars. Congratulations.
I put in new hardware on all brakes (springs and pins). It's worth every penny as it stops the brake pads from rattling and from dragging on the disks. If they are the original springs, metal fatigue has begun and they will be pitted from corrosion. Same with the pins, and they won't slide as easily. On your car, if those are original springs, then they have been submitted to 24 years of extreme heat and corrosion -- bare metal exposed to the elements.
On mine, the difference between new springs and pins vs. the old was amazing. With the old springs/pins the pads moved freely and didn't return to their position in the caliper. Based on subjective testing, the new springs must have had twice the return force to properly reposition the pads in the caliper, and the pads slid far smoother on the new pins.
I think you can no doubt reuse the hardware once with new pads, but from what I saw, after 20 years on my car, the springs and pins needed a replace big time. With the bundle of cash I saved by doing my brakes myself... it was no big deal.
Old 04-11-2010, 02:05 PM
dshepp806's Avatar
Just did my 89 also. ditto.
At that age, it was time for new retainer HW,..keep the old stuff.
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-11-2010, 03:14 PM
In the end I bought new sets but I'm a bit surprised if not worried at how easy you can push them out again once they have been tapped-in. I would have thought that they would remain much tighter. Any comments?
Ex-C4 91
Ex C4 93
A8 3.0 TDI
X5
Old 04-14-2010, 12:28 PM
Senior Advisor
No, that's how they work. And they all seem to work. No reports of pins falling out and dropping brake pads.
08 Cayenne Turbo
Old 04-14-2010, 12:46 PM
Tx James, I'll sleep much better now.
On a sidenote, you've got one of the best natural/organic stores that I ever visited in town. Never saw as much quality food of all sorts together, think it was called the Public Market. Went there last July during a PNW-tour.
Ex-C4 91
Ex C4 93
A8 3.0 TDI
X5
Old 04-14-2010, 01:11 PM
