Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Footwell blower motor replacement.
I searched a lot of posts, but could not find a new replacement footwell blower motor.
The footwell blower assy is available from many sources, but not, motor only. The motors are original to the car, and have already been serviced once as per: Footwell blowers squeaky, how to fix. Which is a great link! Any sources out there? Thanks in advance. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
1984 911 Targa - "Sabine"
Gerry,
Hope all is well. Are you only interested in new motors? Don't suppose you know the bosch motor p/n (I assume it's Bosch)?
Skip 1984 (RoW) 911 3.2 Li Carrera - "Sabine" 2011 Cayenne S |
Bosch P/N
Here's a pic from another member's post. ![]() Thanks, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 10-09-2012 at 05:34 PM.. |
Footwell Blower Motor.
But they only have used. Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 10-09-2012 at 04:28 PM.. |
Hi Gerry,
In another thread Ianc adapted an AC blower motor to the footwell. He indicated it was readily available for $52, but some modding is required for the spade lug connection. Only other issue is that he cites the PN for the AC blower motor as the same one you provided. Could the FW blower PN be instead an AEG W960 80075? please disregard if you already considered this. Replacement footwell blower motor solution
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
That's one of the threads I reviewed. It is a back-up, but I don't understand why these motors are NLA from Porsche, and, so hard to find. We just turned 109K on our 911, don't see a lot of cold weather, but having reworked the two motors once, I'm ready for replacements. Thanks for your input. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 10-09-2012 at 05:37 PM.. |
ROW '78 911 Targa
I read a thread last spring where someone installed blowers from a marine supply company. I'm on my phone or I'd do a search for you. Very Inexpensive swap.
Wider is Better
I know this is an old thread and others have been unsuccessful, but I am going to try to find a replacement motor only for the footwell blowers.
Can anyone tell me what the amperage draw and nominal rpm is for these motors? Thanks
Wider is Better |
I'm currently reworking mine. Really dumb question - how do you get the squirrel cage off? Looks like it's just screwed onto the end of a bolt but I can't turn the cage without turning the motor. Thus, I can't remove it.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
I have a set hanging around.
Footwell Blower Motor assembly, driver probably cheaper than anything new
1988 Carrera Coupe |
Wider is Better
The fan is just pressed on. I removed mine by placing a support under the wide flange of the motor support fan so the motor was hanging down, and then I gently tapped the motor shaft with a hammer and punch to push it down through the fan. Put domething under the motor so it does not hit the floor.
Wider is Better |
Wider is Better
I have measured my motors carefully and have found several possible replacements from asian or european suppliers in the $25 - $50 range, but shaft speeds range from 1800 - 12,000 RPM and amperage draws have a wide range as well depending upon how much torque the motor has. I've got a set of factory manuals and the RPM and amperage draw might be in there, but I posted on the board here hoping for a quicker answer. I've got a couple of months here in North Carolina before I absolutely must have fully functional heat, so I'll give it that long and then buy used or new if I have to.
Wider is Better |
After lubricating the sleeve bearings one of mine drew 5.8 amps and the other 4.5 amps.
Fully assmbled bench test. Didn't think to measure the flow rates. 88 Carrera, ~90k miles. |
