poorsche930's Avatar
Another power window dilema
RH power window moved slow sometimes. Was working fine the other day then just stopped. LH window works fine. Neither rh window switches work (driver side or the rh side) Checked the fuse its good, relay is good, took the 1 working switch and moved it around to the "dead" switches, still nothing. I can hit the rh window switches and it's pulling power because the inside dome lights slightly dim.
Then today (3days later) the rh window worked from the drivers side passenger switch for about 20 min. I took the rh side switch apart and cleaned it still nothing. what I thought was a power window motor has turned into my worst nightmare. Random electrical issues. I'm much better when it's just replacing a part.
Please help. Any ideas where or what to check? Oh by the way it's a 79 930
Ryan
79 930..... among other fine German cars.
Old 04-21-2010, 08:37 AM
French Import
zippy_gg's Avatar
The window mechanism may be binding, which caused the slowness at first, and would also explain the light dimming.
Maybe a disassembly of the window regulator, cleaning, and lubing are in order...
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 04-21-2010, 08:42 AM
Makes sense I'll try that sunday. But that still wouldn't explain why only one switch was working this morning. Thanks. Anyone know if and where the grounds are for the window system. I would also like to check them.
Ryan
Old 04-21-2010, 09:03 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Ryan,
According to our Bentley, for our '86, here is the schematic, and ground location for the power windows.
This may or not be applicable for your year/model.
I would be looking at contact #4 on the driver's side passenger window switch.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-21-2010, 09:36 AM
Some of the colors are different but I think this will be a great help (assuming the grounds are in the same location). THANKS!
I really hate electrical gremlins
Ryan
Old 04-21-2010, 09:48 AM
dshepp806's Avatar
at minimum.....
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-21-2010, 06:32 PM
crustychief's Avatar
My windows were intermittent, there are bulkhead plugs the wires out of the door plug into the outer fender and continue on to their destination. I cleaned mine and everything is right with the world ( to my car ) .
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 04-21-2010, 09:05 PM
Thank you I'll also try this.
Ryan
Old 04-23-2010, 07:15 PM
Cooper911SC's Avatar
Pull the switches out of the doors and clean all of the connections. You can also try spraying some contact cleaner into the switch itself. I just had this exact slow PS window problem problem on my SC. In my case the switch on the DS door needed to be replaced. Cleaning the contacts has worked in the past but this time around no luck...I guess 29 years of use finally took its toll.
If you have to replace the switch get the Genuine Porsche switch not the cheaper "OEM" or aftermarket switches.
My $.02
Cooper
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 04-23-2010, 08:08 PM
