stabilizer bar how to
I am replacing the bushings for my front stabilizer bar. After much effort I got the bar out of the bushings. However, I am having trouble getting the bar back into the bushings. The manual says to push one end in first then the other. When I push one end in, the bar appears too wide by about an inch to go in on the other side. I am referring to the bushings closest to the front of the car. Any advice will be much appreciated.
Thanks!
Sneedster
Old 04-20-2010, 07:18 PM
What year / type of bar?? early thru the body or other??
And as always PICS help
Regards
Old 04-20-2010, 07:49 PM
steely's Avatar
agreed a little more info needed. Are you talking diameter? Bentley mentions using Contifix or rubber lube btw but are you talking mechanical obstruction?
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 04-20-2010, 08:44 PM
Senior Advisor
James Brown's Avatar
check out the come-a-long, hose-clamp thread, very slick.
08 Cayenne Turbo
Old 04-20-2010, 09:30 PM
