jld jld is offline
3.2 engine swap from 2.7
I'm getting ready to exchange my 2.7 [76] for a 3.2 "kit" I bought and have a few questions. I have a virtually brand new fuel pump on the car, will it work with the 3.2? I have a spare set oil tensioner update kit for my 2.7, does the 3.2 need this upgrade? and last I have headers and a sport exhaust on the 2.7, will it work with the 3.2???
Thanks.....jack
Old 04-24-2010, 04:39 AM
Good move.
The fuel pump will work for the car although the pressure is higher than the motronic requires. The Carrera will have the updated tensioner already installed.
The exhaust, the difference will be the 3.2 has thick flanges where the headers meet the heads so you ll have to shim bigtime to get it to seal.
Bruce
Old 04-24-2010, 05:12 AM
jld jld is offline
Thanks for the input! I'm assumeing I could regulate the fuel pressure in line. If the exhaust system will flow well enough for good performance, then I have a friend with a machine shop who will make whatever I need for spaceing.
Old 04-24-2010, 01:26 PM
Warren Hall Student
Bobboloo's Avatar
The 3.2 EFI will regulate the pressure no need for additional regulation.
The exhaust studs are longer on the 3.2 heads. You can either swap the long studs for short studs or put a spacer between the nut and the header flange.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 04-24-2010, 01:58 PM
Warren Hall Student
Bobboloo's Avatar
Bobby
Old 04-24-2010, 02:08 PM
jld jld is offline
I would replace the studs anyway ...so thats good info
thanks...jack
Old 04-24-2010, 02:52 PM
E Sully's Avatar
The studs do not come out easily. Many snap off and have to be drilled. Quite a few posts on this. I made spacers for mine. Good luck with the swap.
Ed
1973.5 T
Old 04-24-2010, 03:02 PM
jld jld is offline
I'll definately keep that in mind
thanks
Old 04-24-2010, 04:29 PM
