However, I also remember reading somewhere (can't find it now, but very likely this forum) that the 915 has a baulking mechanism that prevents the gear being engaged before the speeds have synchronized properly (e.g. to let the brake bands/synchos do their work). So I think you're working against that if you rush the 1st-2nd shift, especially if changing up at low RPM - e.g. below 3,000 RPM, like in traffic. My '86 915 has always dropped straight in 1st->2nd if I rev to 3,500 or above, the shift takes longer otherwise - and both 915's I've used in my car have behaved exactly the same way. I believe this is Working As Designed, you can't beat the mechanism, so don't try; it'll let you know when it's done and slip straight into gear. Contrary to widely-held belief, a 915 with good dog gears, synchros and brake bands doesn't require you to double-declutch in order to select 1st above 20 MPH - but I happen to know what those wear items cost nowadays, so I prefer to do the work for them.. ![]() Quote:
If you didn't own any of the tools, you could buy them for less than the labor rate - and then you'd have them for the next minor job... I happily pay my independent shop for things I don't feel comfortable doing myself, or don't have the tools/equipment for. Turn stalk is DIY in my book.
'77 S with '78 930 power and a few other things. |
Great info on the bushings.. I was doing a search and this thread came up, thanks for the link to the article. Mine is doing the same thing. Doesn't have a hard time going into gear (ie. doesn't grind) but sort of pops into place. I figured it may be a shifter/bushing issue because my 914 did the same thing till I sorted through all the bushings on the linkage.
Great thread!
1970 Porsche 914 1.7L, 1982 Porsche 911 SC Targa, 1977 Porsche 924, 1979 Porsche 924, 1999 Ducati 900SS |
