Stahlwerks.com
New dash panel
Built a new panel to cover the holes of everything that has been removed. I think it turned out pretty nice. Aluminum is thick enough to mount switches or extra gauges on later, plus I have a matching panel to go on the other side next.
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
Stahlwerks.com
Before....
Nice Job. Just curious though. Did you consider this style aluminium as I think it really looks good with switches
Stahlwerks.com
Yeah, that looks cool, but too bright for a race car. Would look good on an early track rat....
Stahlwerks.com
I did finish the dash panel before she went to the new home.
'89 930
John,
Looks good, how did you bend the aluminum? Did you have access to a large break or is there another way? What gauge alum did you use?
'89 930 3.4, twin plug, crank fire, K27, cams, B&B I/C, coil overs, EVO '73 911 'ol Yeller - 3.0 ST Clone '74 911 green with NV - 3.6 RSR to be '87 951 Red Vitesse Stage 3r, AOR, Ruf, Motion Control '01 996 ECU flash, 911Tuning exhaust, DV, Techart |
Rennline makes a similar panel and it is reasonably priced...
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Stahlwerks.com
The aluminum was bent on a 36" wide break press. Three simple bends. .060-.080 aluminum works fine.
'89 930
Jeff, yeah the Rennline isn't too bad, especially if you don't have access to a 36" break
Thread Tools | |
Rate This Thread | |
