Tach goes wild when blinkers ....
Hi all
some times when I use the blinkers (right or left) the tach bounces in sink whit the blinkers . To see if it an alternator problem , when this happens I stop the the blinkers turn on all the headlights and fogs and this problem does not happen.My car is a 89 turbo
Thanks for your help
Old 05-08-2010, 05:41 PM
dshepp806's Avatar
Grounds?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-08-2010, 06:48 PM
flat6pilot's Avatar
Grounds
+1 for grounds.
Check out the grounding points on all four corners of the indicator lights. If the blinker can't ground properly it will find another path and may be interfering with the tach while trying to do this.
Kyle
1980 911sc 3.2 Turbo, 930 Trans
2006 BMW 330i 6mt (DD)
Old 05-08-2010, 07:07 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Originally Posted by ertech View Post
Hi all
Your issue may be internal to the Tachometer.
Pull the Tach, and use this jpeg and your multimeter to verify
the proper grounds/voltages.
Your turn signal indicators operate on a common ground
which may be intermittent either at the Tach,
or at grounding point G116.
My bet is that the issue is internal to the Tach, the turn signal relay,
or an open ground, and your turn indicators have a new ground path
when you turn on the headlights.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-08-2010, 07:16 PM
304065's Avatar
Bad voltage regulator.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-09-2010, 06:22 AM
muck-raker
kidrock's Avatar
I'm with 304065 on this, I think it may be a bad VR
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-09-2010, 09:15 AM
Hi all
If, as some have suggested, you have a bad VR,
place a voltmeter accross the battery, and start the car.
Your meter should read 13.5-14.5 Volts.
Turn on a few accessories, A/C, rear window defogger ect.
The voltage should not drop more than a volt.
A defective VR might read as high as 16-17 Volts.
If the VR is defective, DO NOT DRIVE THE CAR!
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 05-09-2010, 10:47 AM
the voltage ik ok . the tach did it again tonight for a few minutes with the blinkers than the tach did not respond for a few minutes than went back to life??
Old 05-13-2010, 11:17 PM
dshepp806's Avatar
How about those ground points?
Doyle
Middle Georgia
Old 05-14-2010, 02:09 AM
Easily Confused
dtxscott's Avatar
My money is on a ground issue with the tach. Why? The tach and turn signal indicators (green arrows) share the same ground and are pulling current from the same ground point.
One way to check is to turn on your flashers and see if the problem is "twice as bad" since both green arrows will be active instead of one.
HTH,
Scott
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 05-14-2010, 08:40 AM
Pull off the ground connectors on the ground stud located on the inside of the left front of the hood right by the battery. There's a bunch of brass connecters there. Clean each one with emory paper and reinstall. Bet your problem disappears!
I had the weirdest problem ever on my '80SC, some times when I honked the horn or used the blinkers, the wipers would take a swipe, HUH! Then when at night I turned on the headlights, the wipers would turn on and stay on! Checked everything I could think of, and in my checking of the wiring diagrams I noticed the wiper intermittant relay had a voltage path running thru the wiper switch to the washer motor. I pulled off the wires on the washer motor with the headlights on, and the problem disappeared! Got out my Hi Tech Techtronix meter and "read" ground connection to the washer motor. When I turned on the headlights I read 1-2v on the ground connection! The small voltage was running thru the washer motor windings and was apparently enough to go thru the wiring and "pick" the intemittant relay!
Cleaned all the afore mentioned ground connectors and Voila! problem fixed.
Ground loops can do incredible and amazing things!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 05-14-2010, 09:17 AM
As per uwanna check the ground @ G116, per the CKT I sent you.
1986 911 Targa.
Only in L.A.:
Old 05-14-2010, 11:01 AM
AutoBahned
RWebb's Avatar
uwanna-size the other ground star also - look up way high under the cowl (where it is hard to get to) on the driver's side in the corner
my 73 has one there
Old 05-14-2010, 01:12 PM
well it did it again put the flashers on and no problem only with nthe blinkers. acn it still be the ground G116?
Old 05-27-2010, 10:56 AM
Did you completely clean all the ground connectors on G116 with emory paper and reinstall?
Old 05-27-2010, 11:16 AM
