What is going on Sunday at the Civic Center? There is a huge metal sculpture there. Very cool. |
Corner balance.
UPDATE:
Starting a new Topic under "911T Sporto Brake Calipers Frozen...Help!" Once I get the brakes back in shape I will continue the wheel alignment saga... stay tuned! |
You should also check the attatchment from the strut to the ball joint. These can come loose on these cars.
OK. If your strut/spindle is not bent, there is a possibility that your left front wheel bearing is loose too.
How do you check for wheel bearing looseness...with wheel on, see if there is play at 12 & 6 and 3 & 9 o'clock positions? |
"with wheel on, see if there is play at 12 & 6" and off the ground.
Here are some pics of the wishbone area. There are two tabs with a hole thru them and are bent slightly...what are they for??
http://forums.pelicanparts.com/uploa...1273868611.jpg http://forums.pelicanparts.com/uploa...1273868714.jpg http://forums.pelicanparts.com/uploa...1273868800.jpg |
Front sway bar a standard equipment item?
Will post pics in the appropriate forum area. |
On certain cars, yes. Look under to see if it's attached via a nut as some after market bars supply the u-tab which allows you to drill a hole and attach it with a nut.
Okay. Got the brakes in order and returned to the alignment shop.
I watched over and worked with this different technician at the same shop. The numbers improved in the rears: -1.4 camber. The fronts were hitting the limits to the point that he could not even balance the camber: -2.0 left 0.4 on the right. The recommendation was to grind the holes out to get more range! Is this uncommon? I have no ideal how old the front struts are, perhaps this could be the problem as well. Also the car is likely lowered (not my me) as this was often done for appearance sake. Any recommendations? Will post pics later... |
Go to a shop that sets up Porsches for the track. They will know what to do and how to get you there.
I had my car lowered, aligned and corner balanced by Rothsport Road abnd Race and the results were amazing. Costwise, it was about the same any any other decent shop. |
Here's some info regarding cars that are refreshed without questionable issues, age of shocks, strut inserts, etc.
http://forums.pelicanparts.com/porsche-911-technical-forum/533471-need-alignment-help.html David |
| All times are GMT -8. The time now is 09:10 AM. |
