ohbugger's Avatar
Red face Shorted something in left side of engine bay?
In the process of removing my braided plug wires, I think I may have shorted something out near the fuses on the left side of the engine bay. I had the plastic cover off of the electrical bits there, and happened to brush where the fuses are with the plug wires. I thought I heard a low "sizzle" sound followed by just a little bit of smoke. What's the worst damage this could have done? And being someone who is totally "in the dark" when it comes to electronics, how can I test the circuits?
I have since disconnected the battery...
1975 911 S Targa
Old 05-14-2010, 04:22 PM
Rear Fuse panel........
The two (2) bottom fuses look good to me. The top one is hard to tell. The brief 'sparking' you have caused would not damage or break these fuses. Hook the battery back and inspect the fuse panel very closely. If there was a 'short' you inadvertently created, one of these fuses would have been busted by the time you removed the battery. You should be OK.
Tony
Old 05-14-2010, 04:57 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Someone will have to chime in with the fuse designations.
The top fuse appears to be a spare.
I suspect that the other two are for the rear window defogger,
and the heater blower.
The top fuse appears well worn as do the other two.
Try cleaning the connections and replace the fuses.
Then check if your assigned items are working.
There should be voltage on BOTH sides of the fuses.
It is very possible that you did not damage anything.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-14-2010, 05:04 PM
