Is there any change if you retard or advance initial timing?
Richard |
i can ease some of it out if i advance the timing, but not totally
...but not totally. Rats!!
Gordon, I'm useless to you at this point. It appears that elec is good. It stutters initially when your initially ask for more fuel,but then cleans out & runs like a champ. Almost sounding like fuel or small airleak. I don't remember if you replaced the fuel filter or not. I'm guessing you did. I hope someone with far more expertise chimes in. Hang in there! Richard |
How confident are you that the valves are correctly adjusted? A too-tight valve can sound like a miss or an exhaust leak under load.
Brian
'82 SC Targa '83 SC Cabriolet |
brian,
we have adopted the back to basic approach the methodolgy is now leading us to go back to the valves and see where we are with them |
Anyway, what would be different in a no load vs. under load state at 1,000-2,000 rpm? Throttle position would need to be different (more open when loaded). What does this affect? Air box vacuum, which affects initial advance and the mass airflow sensor. I would focus my efforts in those two areas. Things like valve adjustment won't have such a narrow range of affect. Have you checked the vaccum advance/retard mechanism?
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
also my apologies for the description of the issue not being so good.
i am veering toward the vac advance on the dizzie. when i cleaned out the dizzie i removed the vac unit which didnt hold a vacuum well and if shaken made a noise like a childs rattle!! holding my breath for monday when the new one arrives. Gordon |
