Engine Displacement Question
I want to find out what is the largest diameter cylinder and largest stroke crank
I can put into a 3.0 SC case.
Rick T |
I want to start with a 3.0 case since most members think this is a very strong case.
Rick T |
3 restos WIP = psycho
Ping Charles Navarro at LN Engineering to check - cnavarro on this forum. IIRC it is 102mm at the bleeding edge, but 100mm is the ideal max.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
As far as the crank goes, I think you can use a 993 or GT3 crank and stroke it to 76mm.
