how can i tell if i have the chain tentioner upgrade?
What signs can I look for to determine if my car has the tentioner upgrade? It's a 79' and does have a pop off valve and turbo tie rods, witch make me wonder about the chain.
Thanks! Sean |
Max Sluiter
Are their oil lines running to the timing chain covers?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Band.
Here's an ok pic:
![]() When you're looking at the engine from the back, There is a medium-size oil line that comes from the middle of the engine on each side. The left one comes from right behind the distributor over to where the #1 spark-plug is (approx.) On the right side, about the same. The standard lines are about the thickness of your pinky finger. When you have the "tensioner update", in approximately the middle of each oil line, there is a "T" fitting, and a tiny oil line (about as thick as a fat piece of spaghetti) that goes down and into the chain cover (big flat cover) on each side of the engine, like in the above pic. The two red arrows on the left of this pic are pointing to the chain cover area and the little lines that tell you you have the update. There's some brass standoffs that hold the tiny lines in place so they dont vibrate too much. .
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII Last edited by Gogar; 05-19-2010 at 09:29 PM.. |
Here is a little better picture of the oil lines for the tensioner on the passenger side of the engine. If you have this oil line going to the chain covers you've got the updated tensioners.
Fred 76 911s WB 3.0L 72 Int. Scout II 06 Mustang GT "Limping in the right direction is always faster than running the wrong way" |
They look like this:
if we get any closer now we will see what the inside looks like...
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
Looks like the last one has a slight leak at the Fitting! You may want to remove it and clean or sand with 1000 grit the faces and tighten up again?
Perfect Picture!
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si |
