how can i tell if i have the chain tentioner upgrade?
What signs can I look for to determine if my car has the tentioner upgrade? It's a 79' and does have a pop off valve and turbo tie rods, witch make me wonder about the chain.
Thanks! Sean
Old 05-19-2010, 09:10 PM
Max Sluiter
Flieger's Avatar
Are their oil lines running to the timing chain covers?
Old 05-19-2010, 09:24 PM
Band.
Here's an ok pic:
When you're looking at the engine from the back, There is a medium-size oil line that comes from the middle of the engine on each side.
The left one comes from right behind the distributor over to where the #1 spark-plug is (approx.) On the right side, about the same.
The standard lines are about the thickness of your pinky finger.
When you have the "tensioner update", in approximately the middle of each oil line, there is a "T" fitting, and a tiny oil line (about as thick as a fat piece of spaghetti) that goes down and into the chain cover (big flat cover) on each side of the engine, like in the above pic.
The two red arrows on the left of this pic are pointing to the chain cover area and the little lines that tell you you have the update. There's some brass standoffs that hold the tiny lines in place so they dont vibrate too much.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 05-19-2010, 09:27 PM
Here is a little better picture of the oil lines for the tensioner on the passenger side of the engine. If you have this oil line going to the chain covers you've got the updated tensioners.
Fred
76 911s WB 3.0L
72 Int. Scout II
06 Mustang GT
"Limping in the right direction is always faster than running the wrong way"
Old 05-19-2010, 10:00 PM
HarryD's Avatar
They look like this:
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
nineball's Avatar
if we get any closer now we will see what the inside looks like...
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 05-19-2010, 11:05 PM
Looks like the last one has a slight leak at the Fitting! You may want to remove it and clean or sand with 1000 grit the faces and tighten up again?
Perfect Picture!
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si
Old 05-20-2010, 07:07 AM
