1974 911 w/ 83 SC engine
What will replacing motor mounts actually do for me?
A lot of the write-ups for replacement motor mounts I've seen say they "enhance driveablility". Now this has to be one of the most vague statements I've ever read. So all advertising speak aside, what will I *really* get out of replacing my stock 36 year old mounts with the sport ones Peli sells?
Soldier of Fortune
Better shifting, for one.
I noticed less motor vibration at idle, assuming yours are worn and flat.
1988 Carrera Coupe |
Keepin' it Simple...
36 year old rear motor mounts????
You will get the piece of mind that your engine will not fall out/drop unexpectedly!!!! Just my 2 cents...
-Doug 1968 911R Clone; 11/07-?? (forever the project car ![]() 1978 911SC Midnight Blue Metallic Coupe; 7/05-11/09 (so long impact bumpers) 1973.5 911T Sepia Brown Coupe; 9/98-8/99 (went to a great home) 1973.5 911T Gulf Orange Targa; 5/97-11/02 (went back to Germany) |
grateful user
car will feel like more torque, as you have taken the flex out of the drivetrain
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
Anachronistic Anomaly
Also, if you're replacing the motor mounts, you should replace the tranny mounts at the same time. They're probably just as worn. With new motor and tranny mounts, the throttle response will feel immensely quicker and everything just feels tighter.
IG@ the_derek_whitacre Last edited by lfot; 05-22-2010 at 05:38 PM.. |
+1 to all of the above.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
+1 again.
I used to notice a lot of deflection when things were hot. I guess the old rubber in the old mounts got nice and soft on long runs with high temps on 90 degree days. Now all is firm all the time. Nice easy upgrade. |
How does it make shifting better exactly? I've read this but never really seen it explained as to why. My car takes forever to go into 1st thru 3rd gear. It's to the point where I just place the shifter where it's *suppose* to be, and basically wait for the transmission to accept the shifter and go into gear.
If motor and trans mounts can fix that, then my happiness is eclipsed only by the embarrassment of not doing it earlier. |
Soldier of Fortune
Thread Tools | |
Rate This Thread | |
