nineball's Avatar
another brake light question
i have read about 20 threads so far but none of them seem to really address my particular problem, so here is another one. the car in question is an 83SC.
a week ago a friend told me that only one of my brake lights were working, so i decided to refresh all the bulbs both front and rear to sleep better at night. did this and still only one brake light works, the passenger side. the driver side light is constantly on. all of the threads i read mentioned that both lights were wired together, so how only one is working i am not sure. the passenger side works normally and comes on with minimal pressure/movement of the brake pedal but the driver side never changes. does this sound like a brake light switch problem?
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 04-04-2010, 09:28 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
I don't think you have a brake light switch problem.
Also, you don't indicate if the driver's side is always on with the ignition/light switch turned off.
However:
"Assuming" that you installed the correct type (dual filament) bulb(s), I had a very similiar issue many years ago, but do not remember if it was the driver's or passenger side lights.
I replaced the diode as per this factory manual and resolved the issue.
Good Luck,
Gerr
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-04-2010, 09:41 AM
However:
Good Luck,
Gerr
1986 911 Targa.
Only in L.A.:
Old 04-04-2010, 09:45 AM
nineball's Avatar
yes the correct dual filament bulb was used (7xxx series not the 1157). the light is constantly on when the car is on and the lights are on. if either is not then the light is not on.
just out of curiosity, could this be somehow related to the ash tray light? a week or two ago the shielding on mine finally gave out and it grounded, causing the cabin to fill with more smoke than i have ever seen in a car in my life. i traced and removed the positive line for the ash tray light as i really have no need for it.
thanks for the wiring diagram but it is lost on me.
Old 04-04-2010, 10:00 AM
Well, now that's a big hint.....
Assuming this anomaly surfaced after your "smoky dash",
Look under your dash (knee pad) between the steering column and the ventilation controls & radio.
There should be a flat plastic connector which holds a diode.
You can replace the diode with an euivalent from an electronic shop.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 04-04-2010, 10:14 AM
nineball's Avatar
thanks for the tip, i will try that. i can't say for sure if it was happening before the smoke invasion or not. am i safe in assuming that radio shack would have the necessary diode? if not are there any specs or numbers that i should be searching for as a replacement? lastly, and i know this is a longshot, but by any chance do you have a pic of this plastic connector?
Old 04-04-2010, 10:35 AM
Tell the Radio Shack guys where and how the diode is being used.
Or: The Porsche part # is on the schematic.
50V 1 Amp should do it.
You can also connect two diodes in parallel to increase the current capacity.
If you lookk under the knee pad, you should be able to see the diode holder.
Look for a green/red wire as per the schematic I sent you.
One side of the diode goes to the light switch.
I'm not positive that this a fix for you, but it's a good candidate.
Gerry
1986 911 Targa.
Only in L.A.:
Old 04-04-2010, 10:49 AM
Recreational User
porschenut's Avatar
So, did you get this resolved? I have a similar issue right now - my driver's side brake light doesn't work, just the parking light. I'd like to know what the resolution was for your problem.
Old 05-24-2010, 05:58 PM
nineball's Avatar
my bulb was in reversed.
Old 05-24-2010, 06:02 PM
Recreational User
porschenut's Avatar
Thanks. My problem was similar, as it turns out. The bulb had partially unseated itself in the socket.
Old 05-24-2010, 09:16 PM
midnight911's Avatar
i had contact problem in the socket for similar symptom...polished inside the socket with dremel and addressed the problem.
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 05-24-2010, 09:55 PM
