TurboRuf's Avatar
85 930 Engine Bolt Question
I recently removed my muffler a noticed bolt #1 in the photo below wasn't tight. It doesn't appear to be contacting any threads. Does this bolt thread into the engine case? Anyone know how long it should be?
85 930 Ruf BTR
Old 05-24-2010, 01:46 PM
Senior Advisor
James Brown's Avatar
Humm, mine doesn't appear to be there also...
08 Cayenne Turbo
Old 05-24-2010, 02:13 PM
Crotchety Old Bastard
RarlyL8's Avatar
There is a long spacer behind that bolt. The bolt itself is very long and screws into the engine block. It is often left off because you cannot remove the bracket with the turbo in place (due to the turbo studs going through the bracket. Quite often that bolt is stripped as well.
Old 05-24-2010, 03:12 PM
Walt Fricke's Avatar
Brian
Are these extra unthreaded castings on an SC/3.2 case there for various Turbo bits? And just don't get tapped for NA motors?
Last time questioned their function some thought they were there to support cam gears instead of chains for the Porsche airplane motor.
But one of them looks like where you say the mystery bolt should fasten. And the picture makes it appear that there are some extra bolts on the right side of things also.
Walt (not that intimate with turbos)
Old 05-25-2010, 12:54 AM
