shh-the robot is sleeping
Engine and Trans mounts Questions
It looks like these are the same part - is this correct?
Also, am I right in thinking that there are 4 for the engine and 2 for the trans?
Does any one know the torque specs?
Thanks for the help!!
-Dan
'88 911 Coupe, 69k miles
Old 05-24-2010, 06:47 PM
Max Sluiter
Flieger's Avatar
2 engine, 2 trans, same part. You can use different hardnesses of aftermarket components if you choose.
edited thanks to Oh Haha
Old 05-24-2010, 06:50 PM
Oh Haha's Avatar
You need 4 TOTAL. 2 for the transmission and 2 for the engine.
I installed the sport mounts and they worked well for me. Mostly street driving.
Pacific Blue
Wayne
Old 05-24-2010, 07:12 PM
Thanks - I was just about to order 6. You guys are great!!
What is the real difference between OEM and sport?
Old 05-24-2010, 07:43 PM
enjefriy's Avatar
sport has less compliance compared to the OEM. The sports hence droops lesser, and locates the engine/Tranny in a more rigid manner by comparison.
Interms of engine vibration transmitter onto the chassis, it has been said that a bit more would be transmitted thru.
Thou i couldn't tell actually.
But I'd still get the sport. Great balance for my street machine as it doesn't compromise comfort to me.
Old 05-24-2010, 07:48 PM
AutoBahned
RWebb's Avatar
2 levels of Wevo also - if the sport mounts are too soft for you
mix & match fwd and rear (engine: stiffer) to get what you want
Old 05-24-2010, 08:02 PM
grateful user
don gilbert's Avatar
I put the sports in mine and like. I think they came on cabs as standard equip.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 05-24-2010, 08:08 PM
