Broken part but I can't find it on host catalogue?
I must be inept....my o2 sensor connector (orange / brown plastic) is broken (see pic) but can't find a replacement...they still make these?
Do you think I can glue it fixed then still plug into it or is the signal too low.? Thanks, Graham
"Penelope" 1980 SC Targa in Grand Prix White Last edited by grahamkissack; 05-24-2010 at 08:50 PM.. Reason: typo |
My car does not have the o2 sensor but I found this thread..
Oxygen Sensor - 1 wire connection
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
I just replaced the crumbling connector with a bayonette connector from Radio Shack. Used some heat shrink tubing and called it good. I did wonder if the voltage was slightly off from this. The car runs very well so I think all is well.
Larry |
80 911 SC, Orem, Ut
Mine was broken also. I used a water tight speed connector. Then shrinkwrapped it. Working great.
Rob 1980 911 SC |
I had the same problem, the PO had replaced the original connector with a spade connector, but also crimped the shield to the main wire. I failed emissions testing every year until I found the grounded O2 wire. After I fixed it the O2 works great but I have a slight miss at idle which opened a new can of worms.
