bruni911's Avatar
passenger side power window switch
Hi guys i am so *^&(&(* frustrated my power window for the passenger does not work either on the drivers side and the passenger side just my drivers window works i have bought new switches and still nothing i think they are wired right could it be the window regulator, just do not know black on black no air its very hot...
Thanks Dave
Old 05-25-2010, 05:16 PM
pete3799's Avatar
Have you verifyed that the window motor is OK?
Pete
79 911SC RoW
Old 05-25-2010, 05:38 PM
bruni911's Avatar
how can i verfiy the motor is ok?
Old 05-25-2010, 05:44 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Thanks Dave
Dave,
Let's begin at the beginning.
What is your model/year?
Do you have a Bentley?
And,
Do you have a meter?
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-25-2010, 06:47 PM
bruni911's Avatar
okay
1987 930
no i have no bentley manuel
i will buy a meter tommorrow
i have a extra motor but no sure if its for the drivers side or passenger?
I know it works but not sure the side is there a way to tell?
Old 05-25-2010, 06:53 PM
schumicat's Avatar
you need to apply power and ground directly to the wire connections on the window motor itself (using jumper wires). that will tell you if the motor works.
Old 05-25-2010, 07:13 PM
Northern Motorhead
wildcat077's Avatar
Bruni,
I had an issue two weekends ago where i removed the door panel to change the speakers and my passenger door window would not go up or down anymore...Wasted a whole afternoon trying to figure it out,testing for power,switches,etc...
Turns out the wires on the connector plug that goes to the motor were pulled really tight and were not making good contact.
The connector is approx 4 inches above the speaker hole,locate it and make sure the wires have enough looseness and are not nearly pulled out of the plug like mine were.
That solved the problem for my window.
They were intermittent for a while before that and slamming the door harder than usual would make them work,although that is not a recommended fix ... lol
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 05-25-2010, 07:39 PM
Originally Posted by wildcat077 View Post
Bruni,
Cheers !
Phil
Bruni,
This is worth a try prior to buying a meter.
I do recall passing this suggestion on to wildcat a few weeks ago.
The connector/wiring harness does tighten up over time.
As always, please let us know what you find.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 05-26-2010, 06:55 AM
woland's Avatar
Hi Dave
Assume that normally the engine works
To test it, you have to connect the green and black wires coming to the switch with an external 12V power source (ex. a battery charger). It's indifferent if + and green or + and black:
With the wires in one position the window goes up, with the other goes down
When you verifyed the engine you have to verify the wires
The power of the passenger engine comes PRIOR to the driver side and THEN to the passenger door through the hood.
Under each fender near the door hinge there's a soket. Disconnecting it you can verify that there are no cracks in the wires testing the contacts one by one
Normally, I use a 4 meters long external wire and an ohmeter: connect the extremities of each wire to the ohmeter and verify if the contact closes. In not, a wire has a crack.
The cause is opening and closing the door for 28 years
If every wire is ok, you can check the switches. But you tell you have changed it
Hope I have been useful
Paolo from Alps
1980 911 Targa SC 3.0 - Silver metallic
1980 Ducati Pantah 500 - Red
1989 Yamaha 500 "Tracker"
Old 05-26-2010, 08:27 AM
Northern Motorhead
wildcat077's Avatar
Gerry,
Thank you for your help,along with all the others who chimed in for my power window issue... I won`t mention the part about trying to manually lock my door with the driver`s door open... That`s another adventure altogether ... lol
Reading could be the best repair procedure !
Cheers
Phil
Cheers
Phil
Old 05-26-2010, 09:07 AM
