My other ride is a C-130J
RNajarian's Avatar
Slow to return to normal Idle
Interesting Situation;
My Car has a 1983 SC Motor.
When I start it up it runs normally. When I rev it up to 4000 RPM it will return to normal idle 850.
HOWEVER after it warms up things change.
I will rev it up to 4000 and it will hold there for 5 seconds then SLOWLY return to idle, this time 1200.
At first I thought it could be a sticking accelerator cable but I've ruled that one out. Now I'm thinking it has something to do with the warm engine.
A good pal who knows 911 motors very well suggested it could be the spark distributor weights hanging up.
Any thoughts?
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 05-25-2010, 09:17 PM
crustychief's Avatar
Unplug the vacuum line from the decel air valve and see if the problem changes. Is your cat still in place with the 02 sensor hooked up?
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 05-26-2010, 06:59 AM
RNajarian's Avatar
No O2 sensor. The "brain" and 02 sensor were bypassed. My friend who did the engine drop bypassed this system.
I removed the vacuum line from the decel valve (the silver saucer shaped thing) and did not notice any difference
Old 05-26-2010, 08:40 AM
Senior Advisor
James Brown's Avatar
The hack bypass might be the problem. You might have disconnected the electrical wires but the system might still be working in "limp" mode. And there could be several vacuum leaks going on.
08 Cayenne Turbo
Old 05-26-2010, 10:29 AM
RNajarian's Avatar
It might be the problem. He got direction from fellow racers who have done it in their track cars.
The one thing that stands out to me is that it only happens when warm. That cannot be a coincidence
Old 05-26-2010, 10:51 AM
