CVJR's Avatar
Question Need Speedometer fix for 911 SC
Hi, I've only posted a couple of questions, so thanks in advance for your reply. I have a stock '83 SC with 110,000 miles owned 9 months.
Problem is the speedometer reads 10 mph or so low. Odo works, speedometer otherwise works smoothly, tire size is stock/ correct.
What do I need to troubleshoot to fix? visconage@verizon.net
Old 05-31-2010, 09:14 AM
Somatic Negative Optimist
Gunter's Avatar
Pelican or North Hollywood Speedo will calibrate and also replace the infamous plastic gear that usually breaks.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 05-31-2010, 10:07 AM
Senior Advisor
James Brown's Avatar
Check to make sure the pick-up at the transmission is seated and not damaged.
08 Cayenne Turbo
Old 05-31-2010, 10:33 AM
CVJR's Avatar
Thanks for the advice guys. CV
Old 05-31-2010, 06:28 PM
MBAtarga's Avatar
Interesting. I thought the general consensus was that the speedo's read about 5-10 miles high.
Mark
'83 SC Targa - since 5/5/2001
Old 05-31-2010, 07:42 PM
CVJR's Avatar
When I'm doing 50 the speedo reads 60 mph just so I've given a clear description of the issue.
Old 06-01-2010, 03:49 PM
Senior Advisor
Mine is spot on according to me and the Washington State Police
08 Cayenne Turbo
Old 06-01-2010, 03:59 PM
nineball's Avatar
same thing for me - when i am doing 70 my speedo says 81-82, which also happens right at about 28-2900 in 5th. i've often wondered how many extra miles the odometer is putting on and how long it has been happening.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 06-01-2010, 05:06 PM
Gunter's Avatar
Speedos are calibrated to read slightly higher, about 5%.
If it reads 10 M/ph higher, it needs to be calibrated.
The myth that it should read 5-10 Miles higher is the same myth that one has to come to a full stop to re-set the trip meter.
It'll never die.
Old 06-02-2010, 08:53 AM
Wash. State
nesslar's Avatar
LOL....though sorry to hear that....
Old 06-02-2010, 10:06 AM
nineball's Avatar
i have 16s, 205/55 and 225/50
Old 06-02-2010, 10:32 AM
MBruns for President
JeremyD's Avatar
North Hollywood will recalibrate it for you - and make it look purty. They also do some nifty custom work...
Old 06-02-2010, 12:08 PM
CVJR's Avatar
Thanks for the comments everbody. Seems the concensus is that I should send the meter in for calibration, assuming mo loose or damaged sensor connection at the trans. Chuck
Old 06-06-2010, 04:32 PM
I thought the spedometer was just a suggestion? Mine is definitely reads high so I just use the RPM and selected gear to estimate speed.
Ken
'83 SC Cab
'11 Audi A4 Quatro 6sp.
'02 VW Passatt
Old 06-06-2010, 05:22 PM
I used my GPS to compare to the speedometer reading and found it is was running 8-10 mph faster. Sent it out for calibration... now it is spot on.
Old 06-06-2010, 06:04 PM
