no start when engine ishot
after running 76 911s, which runs great,I will park for an hour or so, and engine will not crank, but I hear tte solinod clicking, battery is new, car will start with jumper cables,any suggestions I would appreciat. Thanks for any help, Norm
Clean your battery terminals,clean the ground behind the battery,clean the ground strap
between the trans. and the body (front side of trans.) See if that helps.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Your going to need a new starter.
1982 SC |
If your car will start in that situation when jumped, I wonder if your alternator is not charging your battery? Have you checked the voltage at various times and stages etc...? I had a similar situation w/my '74 911 a few years ago where it wouldn't crank shortly after a long drive. I could bump start it though - never tried jumping it. After checking the battery voltage at various times, I replaced the starter and the issue disappeared. Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
no start hot engine
Thanks for your replys, grounds are good battery holds charge solinoid on starter is good, replaced a short time ago, may be the starter is bad,It seems if starter was bad, then jump from another car would not fire the engine either, Norm
Norm
I went thru this on my car. trust me after trouble shooting everything I could and reading a lot of threads I just needed a new starter. There are lots of threads on heat and starters if you want to take the time. My wife and I pulled off the 10 on the way to Vegas to stretch our legs and where stranded in the desert for a while the first time this happened to me and I wish I just replaced the starter the next day instead of checking everything else first. The starter is fairly easy to replace and there is lots of threads on how to do it Good luck Steve
1982 SC |
