ts
1983 911 speedometer problems
Speedometer quit working I pulled it and sent to speedometers plus in LA. Technician there said it worked fine and sent it back to me no charge. Said I should check speedometer cable, I don't think that I have one. He also told me to check ground wire. Any suggestions?
What year????
don't double post
ts
ts
speedo for an 83 is electronic, no cable.
check the connectors at the back of the guage first. also check the wires at the sender on the trans. Mine had an intermittent problem after I did some work on the fuse box, turned out that I accidently left the 12V supply wire to the dash\guages loose at the fuse block.
Jim Dowty 97 911 Coupe (Forest Green metalic, sunroof, leather) PCA RSR region Insurance chair and Board member Gruppe B #309 |
Check the connection at the shift coupler.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Senior Advisor
And check the sender at the transmission.
08 Cayenne Turbo |
Thread Tools | |
Rate This Thread | |
