Idle problem, help needed.
I can't seem to find an answer to my problem in any previous threads. I took the my 72T MFI out Sunday for an hour, warmed it up on the freeway all seemed fine. At the end of the freeway off ramp I slowed down for the stop and the car just died. Started up fine but would not hold an idle. I had to really work the hand throttle to keep it running. I parked for 5 minutes and restarted. Ran and idled fine. Then later the same problem returned. I notice the RPMS drop way down even between shifts during normal driving. Any suggestions as to where to begin?
Old 12-18-2001, 06:56 AM
Idle Problem
I've got a 1987 911 with mass flow sensor ( MFS has about 70,000 miles on it) that is giving me similar fits. Every other day it won't hold a steady idle. A few months ago from time to time it would not take anything more than part throttle and wouldn't idle steady but rather searched from near dying to 1,500 rpm and back again. At that point we replaced the O2 sensor, cleaned out the fuel filter (maybe I should just replaced it but its only a year old) and adjusted the fuel mix. I also put the spare DME relay in but no change. Seemed to run fine for a couple of weeks until it began to give me idle fits every week or so searching from near dead again to 1,500 rpm. At that point I cleaned the fuel tank and replaced the idle control valve. The idle control valve was thought to the the culprit because if I disconnected it the car would go back to a steady idle. Unfortunately its still doing it on a daily basis. Runs fine but idles crappy every so often. I also replaced the throttle switch a couple of years ago.
Any ideas would be appreciated 'cause this is really getting annoying in daily traffic on the way to work.
Old 12-18-2001, 07:14 AM
Have you done a search through the vast storehouse of previous knowledge? I think this is always the best place to start. I would guess your 87 is strapped with a lot more equipment that could cause your idle problem. My search revealed several possibles for your vintage vehicle, but very little for an older car like mine.
Old 12-18-2001, 07:41 AM
NYSCAR's Avatar
Send a message via AIM to NYSCAR Send a message via Yahoo to NYSCAR
Check your ignition, plugs, cap, rotor, points, coil, wires, and perhaps the engine ground to make sure everything is ok (easy to do). If everything checks out there, how long has it been since you've changed your fuel filter?
Brad
73 911S Coupe sold
Old 12-18-2001, 07:45 AM
Friend of Warren
Sure sounds like the hose came off to your warm up regulator, the regulator itself is sticking or your cold start solenoid will not turn off.
Kurt V
idle replys
Thanks guys now I have all sorts of things to check this weekend! I'll check hoses, contacts, regulators and cold start solenoid. I'm checking the previous posts on the idle subject this morning for more ideas. Its been one year and about 8,000 miles since last major tuneup
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 12-18-2001, 07:53 AM
try adjusting the screw that hits the micro-switch bolted to the #1 stack until it doesn't trip the switch, or pull the wire off the pump soleniod. (just for test purposes). that way the solenoid won't pull the pump rack to the off position at closed throttle. perhaps the speed relay won't let go of the soleniod so the pump can return to idle position below 1300 RPM.
206 637 4071
Old 12-18-2001, 07:56 AM
Kurt, I went through the WUR about 5 months ago and that was the first thing I checked last Sunday so I know the hoses are ok. I read the Haynes book and they talk about a cold start solenoid but for the life of me I cant find it in the car. Haynes also says something about a microswitch.
Old 12-18-2001, 08:02 AM
J.Walker, you beat me to it! I know where the microswitch is and will do that test. Can you help me locate the cold start solenoid and the speed relay? Do you know of tests to check these components?
Old 12-18-2001, 08:07 AM
Senior Member
is the speed relay the same as the rpm sensor/relay? should be the left aft relay in the engine compartment...I've been chasing a nuisance backfire when I lift throttle, the mcroswitch appears to be working fine with a test light, plan on getting into the other animals during the holidays...
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 12-18-2001, 09:15 AM
the solenoid i'm referring to is on the rear of the MFI pump. (rear, as to rear of car). not the cold start solenoid. when it gets power from the speed relay, (rpm transducer), it pulls the pump rack back beyond the idle position, basically shutting the fuel off, until the relay drops the power to it below about 1300 rpm, where the rack returns to the idle position. use a test light on the wire to the soleniod. raise the rpm to 3000 or more. quickly close the throttle to close the microswitch and you should see power for a moment until the rpm falls below 1300, and then no power at idle.
206 637 4071
Old 12-18-2001, 09:44 AM
It sound like you have got it. While I was struggling with the hand throttle to keep the motor running It was about 3000 rpm and below that it would drop off to nothing. What is more likely to fail the relay or solenoid.
Old 12-18-2001, 09:58 AM
the wiring is the most likely problem. the relay is next in line. warren posted a lot of good info lately on the relay and the wiring. do a search.
206 637 4071
Old 12-18-2001, 10:18 AM
FA-18C: I did some more searching and came up with a wealth of information on the speed switch. Check this thread from Warren Hall. This may help solve your problem.
Good Luck.
http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=8074&highlight=rpm+transducer
John walker- Thanks I'll work on this this evening our maybe weekend.
Old 12-18-2001, 03:25 PM
Check your fuel adjustment. You may be running rich and fouling plugs. I just experienced this on my 76'. I'd run it hard for a bit then would have a hard time at idle. Adjusted the fuel and seemed to be fixed.
Old 12-19-2001, 10:06 AM
jkeyzer's Avatar
Find the big cylinder on the front of the MFI pump with the wire connected to it, and disconnect that wire. This will disable the overrun fuel shutoff and if the problem goes away, you'll know something is awry with that circuitry. I believe if you also pull out the middle fuse in the engine compartment fuse block, you will also deactivate the fuel shutoff.
Check the dwell of your points as part of your ignition tests.
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 12-19-2001, 11:29 PM
