Hi, I've only posted a couple of questions, so thanks in advance for your reply. I have a stock '83 SC with 110,000 miles owned 9 months.
Problem is the speedometer reads 10 mph or so low. Odo works, speedometer otherwise works smoothly, tire size is stock/ correct. What do I need to troubleshoot to fix? visconage@verizon.net
Somatic Negative Optimist
Pelican or North Hollywood Speedo will calibrate and also replace the infamous plastic gear that usually breaks.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Senior Advisor
Check to make sure the pick-up at the transmission is seated and not damaged.
08 Cayenne Turbo |
Thanks for the advice guys. CV
Interesting. I thought the general consensus was that the speedo's read about 5-10 miles high.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
When I'm doing 50 the speedo reads 60 mph just so I've given a clear description of the issue.
Senior Advisor
Mine is spot on according to me and the Washington State Police
08 Cayenne Turbo |
same thing for me - when i am doing 70 my speedo says 81-82, which also happens right at about 28-2900 in 5th. i've often wondered how many extra miles the odometer is putting on and how long it has been happening.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
Speedos are calibrated to read slightly higher, about 5%.
If it reads 10 M/ph higher, it needs to be calibrated. The myth that it should read 5-10 Miles higher is the same myth that one has to come to a full stop to re-set the trip meter. It'll never die.
Wash. State
i have 16s, 205/55 and 225/50
MBruns for President
North Hollywood will recalibrate it for you - and make it look purty. They also do some nifty custom work...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Thanks for the comments everbody. Seems the concensus is that I should send the meter in for calibration, assuming mo loose or damaged sensor connection at the trans. Chuck
I thought the spedometer was just a suggestion? Mine is definitely reads high so I just use the RPM and selected gear to estimate speed.
Ken '83 SC Cab '11 Audi A4 Quatro 6sp. '02 VW Passatt |
I used my GPS to compare to the speedometer reading and found it is was running 8-10 mph faster. Sent it out for calibration... now it is spot on.
