Question Need Help - Becker CDR 210 Code Reset
I had to disconnect my battery and obviously, my Becker CDR 210 is looking for a Code.
Using a code generator, I tried code 4818 but after entering the code, nothing happens but the first number blinks. Is there something else I have to do or is this the incorrect code?
If anyone has a generator, I would appreciate if you could look up
CDR 210
MO = BE2282
SN = W5021438
EC = 106
If not, I will contact becker directly.
I appreciate any advice or help.
Thanks,
Tom
Old 06-07-2010, 06:58 PM
Just an FYI to anyone interested. After entering the code, you must push the down arrow on the right hand control. The code generator on line worked, but like a previous suggestion, I had to go up two numbers.
Old 06-10-2010, 06:03 PM
Tags
becker , cdr 210 , code
