Found source: lug nuts for BBS E52 wheels
I bought a set of 16x7 & 16x9 BBS rims for a song on Craigslist, only to find out later that BBS no longer sells the shouldered lug nuts. Here is a picture of one of these wheel centers:
![]() I searched this forum for solutions, and was disappointed by the suggested solutions -- find some used lug nuts, machine the lugs bores to accept acorn-style shoulders, and even fogettaboutit look for other wheels. ![]() So I mic'd the lug bores, and found the following: Lug Nut Shank Length: 1.095" maximum (depth from inner shoulder to where the wheel meets the hub) Lug Nut Shank Diameter: 0.75" Washer Outside Diameter: 1.25" maximum Using that info, I searched the internet for open end steel lugs and found that Custom Wheel Accessories (714-827-5200) carries them -- part number 5108OP. Since I'm using 100mm length 14mmx1.50 lugs on my Subaru WRX-powered 914 and wanted open-ended nuts, these seemed like the ideal solution. I called ACW on Friday and ordered two full sets (40 lug nuts) and matching chromed washers (part number 6002). With shipping and handling charges, the total was $62.58. They arrived today, and they appear to fit perfectly. ACW also manufactures closed-end nuts, part #5108. Here is a pic of the nuts-n-washers: ![]() YMMV, Geoff |
Very cool. Thank you for your persistence...
JP 86 930/4 tribute beasty 81 sc beach beater ‘55 Belair ‘40 Ford pickup |
Wow, that's great info. I have the same wheel type, but have only been able
to find lugs from Jegs, and they needed to be cut as they have too long a shank. Thanks
Mark S. '70 914-6 |
You're the man! I just ordered 3 sets for my wheels. I have 1 set of 8.5" x 16" wheels, and another in 10"x17". Had no lug nuts for either set and was considering re-machining the wheels, etc.
Good find! Doug Gale TrackMasters Racing |
