Torque Spec?
Anyone know if there are torque specs for the 4 screws which hold down the throttle body on a CIS system?
Also torque specs for the 6 screws holding down the mass air flow meter?
Davy 82 911 SC Targa Sold 12 Audi A5 Sportback 3.0 TDI Quattro 03 996 C4S Last edited by Daviboy; 06-08-2010 at 11:38 PM.. |
a.k.a. G-man
Davy,
From Wayne's rebuild book... (don't yell, ok... ![]() ![]() Those nuts/screws are not specifically mentioned but it does mention following values for "miscellaneous" nuts. here you go: M14 X 1.5 150 Nm (110 ft-lbs) M12 89 Nm (65.5 ft-lbs) M12 X 1.25 95 Nm (75 ft-lbs) M10 51 Nm (37.2 ft-lbs) M10 X 1.25 52 Nm (38.3 ft-lbs) M8 25 Nm (18.4 ft-lbs) M8 X 1 27 Nm (18.9 ft-lbs) M6 11 Nm (8.1 ft-lbs) M4 3.1 Nm (2.2 ft-lbs) Hope this helps.
Сидеть, ложь, Переворачиваться Last edited by Geronimo '74; 06-10-2010 at 03:02 AM.. |
Keep the Shiny Side UP! Pete Z. |
thanks for this old thread.. i searched and searched and found my answer; from 6 years ago!
PP is awesome ![]() |
Earthling
And again, almost 8 years later!
![]() BTW for the 6 screws with springs on the mass air flow meter, Bentley says tighten them down all the way (presumably until snug but not super-tight) then back off one full turn.
1996 Porsche 993 C4. His 1979 Porsche 911SC - sold... and now BACK again! Hers 2021 Volvo V60 (foul weather drive) 2024 Volvo XC60 (spousemobile) Last edited by Brian Cameron; 04-15-2018 at 07:15 PM.. |
