2002 996 C4S
CV Joints - Rebuild or Replace?
Hey all -
I am in the process of having my Transmission rebuilt. When I removed the CV Joints, the ball bearings fell right out. Is this a problem or can I rebuild the CV joints? I have heard that the rebuild can be a bit challenging - like a Rubik's cube. Looks like new CV Joints would be about $320. Parts to rebuild including boots are about $60. I have an '84 911 - apparently things changed a bit in 85. Any advice appreciated.
jcsjcs Have: '02 996 C4S Had: '87 944, '84 911 Carrera Targa |
Senior Member
Nearly all of the CV joints I have inspected were worn. Many were pitted. In my experience, it is fairly rare to come across CV joints that are fine and can be cleaned and reused. I think that if someone disassembled, cleaned and repacked them annually, they would stay fine for a long time. But nobody does that. Used, worn ones can of course be cleaned and repacked. And generally they will provide service. So....I guess it is up to you. My advice, if you can afford them, is to simply replace. Or clean and inspect. Look at the wear surfaces on the races. Pitting is bad. A little wear/discoloration is acceptable. They are not difficult to disassemble and reassemble. There are pictorial, step by step instructions. Probably posted on this site somewhere. Not difficult at all to disassemble and reassemble. Messy, but not difficult.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Registered Abuser
If they are in fair shape rebuild
If they are heavily warn replace. Some excellent threads on this are easy to find with the search function. Type CV Joints Rebuild is not bad, it is very greasy. You will need 2 Roll paper towels 5 pair of rubber gloves Half gallon of lacquer thiner (Cuts the grease) Brake Cleaner Metal cans or bowls for soaking This the best one I have found. Reconstructing Constant Velocity (CV) Joints It not that bad, spend some time reading the CV threads they contain all the fine points.
MT 930 1987 930 - Gone but not forgotten A man with priorities so far out of whack doesn't deserve such a fine automobile. I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen американский |
AutoBahned
take some good closeup pics of the ball bearings & of the cages - post
or just buy rebuilt ones if $$ is not that big an issue |
Fleabit peanut monkey
Everyone is correct in this set of threads. It is like a Rubick's cube. It is greasy. It is not difficult.
But it will suck time. Lots of time for the DIY "noob" (like me) doing this job. You can't really put them back together wrong as they will not pivot freely. They will freeze. I would suggest to scope it out before you buy the gaskets, seals and grease. Clean them up and see if there are heavy wear marks on the thrust surfaces. Slight wear marks are ok. If I had to do it again, I would spend the money and get new. |
the bolts, people...the bolts...
since yours is 84, I suspect you did not see any washers with the six hex bolts holding the CV to the gearbox and hub flunges. getting the bolts in grease free is near impossible but i encourage you spend time and try. also, get moon plates and schnorr washers if you can. M8 Schnorr Safety Washers P/N~?? (CV thing) besides that, rebuild and repack. CVs can go many many miles.
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
2002 996 C4S
Thanks - will update you all this weekend with pics.
An entire new rear axle is only $420 if you go genuine Porsche. You can get one on this website for $320 from GKN and not worry with the grease! 911-332-024-15-M60
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) |
As to grease free bolt installation, this works pretty well:
Clean bolts 1st Install all bolts & tighten to 5 ft/lbs less than spec Remove 1 bolt at a time, clean hole with brake cleaner & compressed air Clean, dry & reinstall bolt Final torque & you're done fairly quickly & without too much mess. |
Registered Lunatic
BTW, I don't know if the link provided above states this. . .I haven't checked it out, but there is a way to redo these (as long as no pitting on the balls or 'races' (if you can call them that) to where you can get the balls to ride on unworn areas of the outer and inner rings. Once you get one clean and figured out, you'll see what I mean.
If'n I tell ya a rabbit can pull a freight train, then son, hitch his ass up! |
I dissagree with MT 930 above: You will probaly need at least 3 rolls of paper towels.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
2002 996 C4S
Pics - as requested. I am leaning towards cleaning and repacking - due to other projects I have to complete right now. Open to suggestions on this....
Seems to be some wear - balls look perfect. ![]()
AutoBahned
looks like minor wear but not too crazy re the color changes...
what does it feel like to your fingertips? to your finger nail? |
2002 996 C4S
Feels very smooth. There is a very slight rounded indent in every other "track" (don't know what to call them.) The indent is not deep 1/10th mm or so?
What's the risk in repacking these and using them?
IMO, this is not only a financial decision. What is your threshold of pain for doing this kind of project?
Do you plan on having them off again, say, next year for an engine drop or bearing replacement? If so, rebuild the CVs and drive them 'till they break. If this is something you want to do once and drive the car for the next 5 or more years, trouble-free then buy new. CVs are a PITA, especially the kind we have. I have never had one come loose, BTW, after careful re-torquing after driving a bit. I get grease everywhere when re-assembling (like most mortals) so don't sweat it.
1979 911 SC Silver 2002 996 race car 2005 Ford Excursion |
AutoBahned
very low risk - some just run them until they get noisy - yours weren't, right?
the real question is the $$ vs. the fun of R&Ring them again sooner than if they were new ones |
2002 996 C4S
Thanks for the advice. Mine were not noisy and I would rather spend the $250 saved (or so) for just CVs OR $400 saved (or so) for axles on other more critical stuff right now.
I only drive 3 to 5k per year - so I think these will last awhile!
Registered Lunatic
Good luck and have a blast!
2002 996 C4S
Does the order of the ball bearings matter?
Do I need to install the same CV to the same side of the car? I am not quite sure if can backtrack and figure out what went where exactly - but don't want to create further problems due to wear patterns..... Immediate Advice appreciated - as I want to start tearing these things apart tonight!
