Chain Tensioner Question...
1974 911S 2.7 (completely stock, or so I thought)
What kind of tensioners are these? Removed Chain box covers to replace seals and install pressure fed tensioners and this is what was installed for tensioners on both sides: ![]() ![]() These appear to be purely mechanical tensioners and are adjusted with an allen wrench. No springs at all. Thanks... Glen
1974 911 |
Fully mechanical tensioner, used for racing engine a lot.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Crusty Conservative
Solid, mechanical tensioners are generally not a good idea on a street car. In order to work properly, they will need adjustment at regular intervals, as the chains wear & stretch.
Carrera tensioners are the best solution for most of us.
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
yelcab1,
Thanks much for the quick answer! Bill, Thank-you for your answer & advice. Can't imagine why these were put on the car. The owner of the car that this motor came from never raced it. Anyway, as seen in the photos, I have already removed them and am putting on the pressure fed tensioners. I guess I can keep them as a tool when working on tensioners and/or cam timing etc. Thanks again to both of you.. Glen Pettigrew
1974 911 |
People use them because the can not fail, and they are fairly inexpensive. I found a set on my 78 SC as well. Carrera tensioners now.
BTW, I am not advocating them in any way. The biggest downside IMO is that they cannot compensate for engine expansion during warm up and cool down. I would expect that if they were too tight they would cause rapid chain wear or stretch, which is similar. Set up properly, I would expect them to be slightly sloppy when dead cold.
But I am not a doctor. |
