dsmyth's Avatar
Idle bounce down vs up? difference
I have read the posts on idle bounce and they all refer to bounce up. For the first few minutes mine drops to 500 then pops up to 1000 then steadies at spec and bounces that way . I have a new ICV, oxygen sensor, fuel pressure and damper, wires, plugs, coil ect. .Just recently installed a 964 cam but it did it with the 3.2 cam. I know this topic has been well covered but I have run out of ideas. I can live with it as It does go away but I would rather solve it. thanks Doug
Doug
97 C2S 993(last one)
95 993 cab- 85 911 M491
87 944 Turbo- 70 914-6
63 911
Old 06-16-2010, 08:18 PM
Is the car chipped? Light flywheeland aluminum pressure plate? Steve Wong says he now has a fix with his latest programs for dip. . I suspect he uses the idle switch to momentarily push the timing foreward to boost the idle speed .That would react faster than an icv could.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 06-16-2010, 08:23 PM
Hendog's Avatar
I chased an idle dip for a while, OK for a few years... I replaced same stuff you did less the cam. I finally replaced the intake gaskets and spacers. It was a intake leak that caused my idle to dip from about 880 to 800 or so.
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 06-16-2010, 08:27 PM
dsmyth's Avatar
I did just replaced the clutch with a lightweight unit but it was happening before that. I also replaced the cylinder temp sensor and all the intake spacers and gaskets. I have double checked the vacuum hoses.
Doug
63 911
Old 06-16-2010, 08:52 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Just a thought.
Had the same issue a while back.
How about the vaccum lines behind the throttle assy?
Could they be transposed or not connected?
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-17-2010, 03:11 AM
dsmyth's Avatar
I will check the vacuum hoses again Gerry but they seem to be properly attached. thanks Doug
Doug
63 911
Old 06-17-2010, 05:33 AM
muck-raker
kidrock's Avatar
check your air / fuel mixture, could be running a bit rich
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 06-17-2010, 08:39 AM
dsmyth's Avatar
The vacuum hoses seem to be all correct. Is it safe to just try leaning the mixture a 1/4 turn to see if that solves the problem. I don't have any measurement tools that would be needed to gage this?
Doug
63 911
Old 06-17-2010, 07:46 PM
Hendog's Avatar
Just covering the bases here; you did a valve adjustment right?
Henri
Old 06-18-2010, 07:27 AM
muck-raker
kidrock's Avatar
Doug,
I took the liberty of searching a thread which contains excellent advice on your dilemma. It's a bit of a long read, but very informative...you could probably start around page 3 and get a handle on what's happening. Good luck.
idle bounce
STONE
Old 06-18-2010, 10:45 AM
dsmyth's Avatar
Not sure where you are going with the valve adjustment Henri but it was required after the cam installation. What are you thinking ?Thanks for the link Kidrock thats got lots of good info in it.. Doug
Doug
63 911
Old 06-18-2010, 10:04 PM
Hendog's Avatar
Just making sure the obvious was done, ie the valve adjustment. I know the engine would be exhbiting greater running issues had the valves not been adjusted but I stuck my neck out just in case it was something weird like that You see some things you'd never would have thought now and again.
So, back to chasing the vacuum leak.
Henri
Old 06-19-2010, 09:01 AM
