tail light not working, checked fuse & bulbs
my left taillight and the engine compartment light is out on my 84. I have checked the fuse, its good plus the front marker light is working. i checked the bulbs and unplugged and replugged the wire connector in the engine compartment a few times. Is there any common issues i should look for before i tear into it?
Old 01-05-2012, 07:00 PM
RETIRED
Joe Bob's Avatar
Look for a corroded brown (Ground) wire in the tail light assembly.
2012 ML350 3.0 Turbo Diesel
Old 01-05-2012, 08:47 PM
LWJ LWJ is online now
+1 Ground
Did you put a multimeter on it?
Old 01-05-2012, 08:51 PM
i havent yet LW, i didnt have it at my house
Old 01-05-2012, 09:14 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
I had the same problem and it was a matter of the copper connection losing it's tension to press consistently against the base of the tail light bulb. removing the bulb, reaching in and pulling the copper connector toward where the bulb's base will sit fixed the problem temporarily. replacement is in the future as well as cleaning up the ground connections to be safe.
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 01-05-2012, 10:55 PM
Member 911 Anonymous
DRACO A5OG's Avatar
After checking with a DVM. consider crack the assembly open to inspect the PCB type board behind the socket. It may have fractured and the contact may have shorted out.
Bending the copper contact may damage the board, so take caution:
When you place the back plate on, use some caulk to seal the housing, if not you will get moisture in there.
'85 Carrera Targa
PCA/POC
Old 01-05-2012, 11:14 PM
thanks ill check it out
Old 01-06-2012, 09:24 AM
AutoBahned
RWebb's Avatar
there is a thread with pics and wire ID that you can search up
Old 01-06-2012, 11:24 AM
Shuz
I got a similar issue, except I don't have any lights on the left front marker and left tail.
The fuse looks good and the break and turn signals are operational.
Where does one begin?
Old 01-07-2012, 10:24 PM
I had same problem, it was a bad diode, its right behind ignition/key switch. It's about 3 inches long. Just disconnect the diode and reconnect the wires, you don't even need it. Tim
Old 01-07-2012, 10:35 PM
muck-raker
kidrock's Avatar
If Timchar's solution doesn't work, check your light under the engine lid. When the fixture goes bad, it cuts the circuit to the left side front marker light and tail light.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 01-08-2012, 09:47 AM
Stone, you're right, probably smarter and easier to check that first. Gotta have small hands to get diode out. Tim
Old 01-08-2012, 09:53 AM
