Loose fan belt, wrong pulley?
I have a euro 1980 911 SC and the fan belt started slipping. I took it apart and all of the shims are on the outside of the pulley, not four inside like the tech article shows. Which prevents me from tightining the belt any further.
The belt is a Dayco and a cross-reference shows that it is listed as fitting my car. I am starting to think that maybe the pulley isn't correct for my car. I have attached a picture of mine, does this look the right pulley?
Old 06-30-2010, 09:52 AM
Packy's Avatar
maybe your belt stretched. When I drove my car from San Diego to Santa Cruz I broke a belt. I had to go through 7 before I found the one that fit spending half a day in a gas station. The one that fit wasn't the recommended belt by porsche.
(1) '77 Chassis and '79 SC 3.0 project car
(1) '79 911SC 3.0 Widebody SC
(1) '15 Ford F-150 4x4 3.5TT
Toluca Lake, CA
Old 06-30-2010, 09:55 AM
gtc gtc is offline
abides.
gtc's Avatar
I've had good luck with the service-free continental belts. I've never had one stretch, and the fit is consistent. I've heard more good reviews about them than even the Porsche-branded belts.
Graham
1984 Carrera Targa
Old 06-30-2010, 09:59 AM
Thats not the right pulley half for the fan, its from another application but not 911 fan.
[B]ruce
Old 06-30-2010, 10:42 AM
Friend of Warren
[B]ruce
Agreed. Way too flared out, no holes for the pulley wrench and has two notches on the outer rim of the pulley. Not a 911 pulley.
Kurt V
Old 06-30-2010, 11:12 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Pulley
Kurt,
This might help.
There should be some shims on both sides of the pulley halves.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-30-2010, 11:32 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Be sure to buy the one pulley outer (all you need), it's a lot easier to place the shims and cup washer. I would buy new shims and cup washer too, but that's me.. you will need the correct Porsche wrench also..
The picture above is good, but they make the washers look like thick spacers rather than the thin shims they are..
Gary R.
Thanks, I thought it looked wrong but wanted to make sure. I'll get the new pulley half, shims, and
cup washer ordered. Hopefully can get the belt tightened and the car back on the road.
Ryan
Old 06-30-2010, 12:33 PM
That looks like a VW pulley with those notches.
Old 06-30-2010, 12:43 PM
GaryR's Avatar
Ryan -
Don't forget the wrench if it isn't in your tool kit, you need to have it, the correct socket, and a spare belt with you..
Ryan
Gary R.
Old 06-30-2010, 01:10 PM
Agreed, old beetle.
Old 06-30-2010, 02:08 PM
Shims
Ryan
Ryan,
On our '86, two shims between the pulleys, four shims in the cup.
Fan belt P/N 999 192 176 50 9.5mm X 710mm.
Gerry
1986 911 Targa.
Only in L.A.:
Old 06-30-2010, 03:12 PM
Immature Member
dentist90's Avatar
Three in, three out is a good place to start. After the pulley is tightened down run that engine for a minute and then recheck the tension. If the belt has become loose again take one of the shims from inside and place it outside the outer pulley half, try again. There is no rule againt having all 6 shims on the outside as long as the tension seems correct. If you've got all 6 shims outside the split pulley and the belt still slips it is time for a new belt.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 06-30-2010, 06:12 PM
muck-raker
kidrock's Avatar
Definitely a VW pulley...and not a very good one, at that. Chuck it and get the correct part.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 06-30-2010, 07:01 PM
AlfonsoR's Avatar
I guess you removed the bolt for the housing strap???? If not, make sure you get one and tighten it down before you install the belt.
Old 06-30-2010, 09:41 PM
SCWDP911's Avatar
Hope you don't mind this sidebar but related question here:
I just got a new fan belt in my latest order from PP and it is a notched v-belt. None of my old ones I have around are notched. It is a Continental belt. Is this the normal now for these. Does the notching help with anything? Or do I have the wrong belt?
Shane
- 1984 928S
Old 07-01-2010, 06:36 AM
No, I didn't, trying to figure that out. Not sure if the bolts the wrong size or if the threads are stripped but when I was working on it I found that it was loose and just spun when I attempted to tighten it. Thanks for pointing it out.
Old 07-01-2010, 06:37 AM
